My engine is dead, need Advice in engine swap!
Old Jul 7, 2018 | 12:00 AM
Pac-man's Avatar
Should I go with the new civic turbo engines or the K20 engine???
Old Jul 8, 2018 | 04:12 AM
ommegga's Avatar
No, put in LS4
Old Sep 12, 2018 | 08:11 PM
Pancake's Avatar
I came here for the same reason. Have you found anything. Also what killed your engine?
Old Sep 12, 2018 | 09:15 PM
GAFIT's Avatar
AFAIK, there are not motor mounts yet for the 1.5T into a GE. Hasport is working on the mounts for a GD.
Figured I would mention since I'm not sure of your fabrication skills.
Old Sep 12, 2018 | 09:19 PM
Pancake's Avatar
Fabricating shouldn't be too much of an issue. which would be an easier and cleaner fit is my main question.
Old Sep 12, 2018 | 09:27 PM
GAFIT's Avatar
That would definitely be the K series. It keeps the same layout (front intake, rear exhaust), doesn't have a turbo to consider, and it much closer in wiring type. Not to mention the whole direct injection needs to go along with the 1.5T.
I don't believe there is a single running 1.5T in any body style Fit yet. That project has to start with an entire donor car in my opinion because you're going to need the entire fuel system, ECU, wiring harness, etc.
benareeno
16
Jun 25, 2025 11:15 PM
Cordizzle4life
Aug 14, 2019 10:21 PM
JacobAlexander
Aug 9, 2014 10:23 PM
Edison Carasio
Sep 6, 2009 10:25 AM
Gordio
Mar 29, 2006 04:36 PM
