Need Help on Crushed Oil filter (Honda Fit 2008)
Old Jul 9, 2018 | 04:34 PM
Honda fit owner's Avatar
Hi Everyone,
I was trying to change engine oil for my 2008 Honda fit but finally ended up crushing oil filter. oil filter is very tight and i used almost all methods suggested online including using screw driver. I am also attaching photos of filter. please help and advice me how to solve this puzzle
Oil Filter current situation
Old Jul 9, 2018 | 09:02 PM
2Rismo2's Avatar
Strap wrench? Place it near the base and hope it doesn't deform too much before it starts spinning.
Old Jul 9, 2018 | 10:26 PM
Thanks a lot for the suggestion I will try strap wrench tomorrow and will let you know. could you please also let me know what could be the worst situation if strap wrench doesn't work?
Old Jul 9, 2018 | 10:36 PM
doctor J's Avatar
Using large 3...3.5 inch opening size vise grips around the filter seam (where the plate meets the canister). There is a small risk of scratching the filter gasket seat outside of the contact area.
Old Jul 10, 2018 | 09:10 AM
Alco RS-1's Avatar
Yep, a strap wrench should do the trick. Dang, that thing is really torqued on.
I tighten new filters by hand, as strong as I can muster with one hand. Never had a leak and they always come off without trouble. Everyone has their technique with this it seems.
Old Jul 10, 2018 | 10:33 AM
2Rismo2's Avatar
Worst case you might have to cut off the filter with maybe a dremel or something like that.
The oil filter should never be torqued down so much though. I just hand tighten it, then maybe just a 1/4" with a strap wrench. The rubber seal should prevent it from backing itself out.
And not to be condescending but, righty tighty, lefty loosey?
Old Jul 14, 2018 | 10:40 AM
greasy's Avatar
did you ever figure this out? I didn't see this thread and am in the exact same situation. But mine is only the head of the filter left. I'm thinking I will have to remove the part that screws into the oil pan if possible.
Old Jul 14, 2018 | 11:02 AM
greasy's Avatar
Just bought this tool and I will see how it goes.
https://bogertaviation.com/products/...to-1500-in-lbs
Old Jul 25, 2018 | 08:32 AM
Andrei_ierdnA's Avatar
Originally Posted by 2Rismo2
... And not to be condescending but, righty tighty, lefty loosey?
I also think that's a legitimate question, especially since everything appears to be weirder while working underneath the car, and might confuse one which way to loosen it up.
I have a strap wrench, but have been lucky enough to be able to remove & install oil filters just by hand. My strap wrench has never been used yet...but good to have it just in case.
Good luck!
Old Jul 25, 2018 | 09:56 PM
knope's Avatar
stab what's left of it with a screw driver and turn hard?
Old Jul 25, 2018 | 10:25 PM
DaGou's Avatar
I think Jiffy Lube is in your future...
Old Jul 26, 2018 | 07:47 AM
doctor J's Avatar
Another example of poor forum ethics:
-someone asks for help and promises an update;
-members give suggestions
-topic starter disappears
-members continue discussion
BenjaminFit
Mar 23, 2011 12:49 PM
helphelp911
16
May 31, 2010 09:12 AM
Lek
Jul 4, 2009 03:34 AM
ricohman
Sep 23, 2008 07:14 PM
smeister
Jul 22, 2006 11:18 PM
