Strut top mount after lowering spring install
Old Jul 10, 2018 | 02:58 PM
Helios's Avatar
So after installing a lowering spring (yea the other side isn't done yet), I noticed that the top piece of the strut is not sticking up as high as it was before. I'm wondering if I didn't reassemble it correctly. Everything is definitely tight. There's no wobble and no noise when driving. But thinking about it, i can't come up with a scenario where that height should have changed at all.
The threaded rod is flush with the flange nut, where before it stuck up about a half inch and had a little rubber cover thing on it.
Can anyone put my concerns to rest? Or tell me I screwed up.
Thanks!
Old Jul 10, 2018 | 04:05 PM
yah probably screwed up. take it off and compare with ur other side.
Old Jul 10, 2018 | 04:20 PM
evilchargerfan's Avatar
should seat flush. got pics to show us what youre working with?
Old Jul 10, 2018 | 10:25 PM
Helios's Avatar
Old Jul 10, 2018 | 10:26 PM
Helios's Avatar
Old Jul 10, 2018 | 10:27 PM
Helios's Avatar
So, ahem, ignore the weld on the 2nd one. See how it protrudes above the flange nut? The side with the spring installed is flush (1st pic)
Old Jul 10, 2018 | 10:33 PM
da hell are u using to work on your car? pliers? lol
take it to da shop before you break ur car!
Old Jul 10, 2018 | 10:35 PM
Helios's Avatar
Check my build thread. Seized strut top nut. The hex key is stripped so I tried welding a socket to it. It snapped that also.
Friday it is getting a cutoff wheel taken to it.
Old Jul 13, 2018 | 07:53 PM
Helios's Avatar
Got the seized one off today, put the lowering spring on and re-assembled. It was replaced with an aftermarket KYB Excel G strut, but this one also left less threads showing. It has about 1 thread poking through.
I disassembled the other side just to make sure and everything looked good, and ride height is even on both sides, so i'm not going to worry about it too much. Those nuts only get 33 ft/lbs of torque, so they don't need to be mashed onto the threads anyway. Just an FYI.
Old Jul 13, 2018 | 08:06 PM
Old Jul 16, 2018 | 02:20 PM
A local down here in San Diego had an issue where his top nut refused to come out.... I'm starting to think Honda really goofed and this may be affecting multiple owners
Old Jul 16, 2018 | 02:25 PM
Helios's Avatar
Here's a picture of my top nut after being sliced almost in two.
Old Jul 16, 2018 | 07:04 PM
maybe the thread pitch is wrong causing cross threading?
Old Jul 17, 2018 | 04:24 AM
UnFitRick's Avatar
I put my springs on last night and I was thinking about your install and the way the top of the strut was lower when you were done. I did not experience that and I'm thinking that something in the top of your strut assembly must not be seated. With the bearing that's in there and all, you may consider taking another look?
Old Jul 17, 2018 | 09:40 AM
Helios's Avatar
On the first side I did (the one that is definitely lower), when I pulled the top hat and dust boot out, everything fell apart, and I had to reassemble the bearing with new grease and everything. This was my main concern for what I may have messed up.
When I did the second side, I pulled the top assembly out in one piece and had no issues. Then I reassembled on the new strut. This one has the stud all the way through the top nut, but not far enough to put the little rubber booty on, and I know it is put together in the correct order. My only thought is that I did not use a spring compressor when I reassembled the strut assembly. Is it possible that the spring pressure is what allowed me to apply the torque, but that wasn't actually in the fully torqued position. Meaning, if I compress the spring and tighten down the nut that holds the bearing on, would the nut travel further downwards? That would shift everything up and fix my issue.
Did you compress the springs prior to torquing down the nut that holds the spring assembly onto the strut? That's the only place I can think I did differently. But now it's definitely bothering me and it's going to get tore apart again no matter what.
Old Jul 17, 2018 | 07:43 PM
I did not use spring compressors for my d2 springs, b&g, nor my tein's. impact gun, ftw
Old Jul 17, 2018 | 07:55 PM
UnFitRick's Avatar
I did not need a spring compressor to install the new springs (nor did I use an impact wrench). In fact I didn't bother using compressors to remove the second spring from the strut. But then again, Danger is my middle name...
Still waiting for my Bisimoto to ship; I blame you...
Old Jul 18, 2018 | 03:43 PM
prior to ordering mine, I think their website said like 10+ in stock or something along those lines. perhaps, I should have approached Bisimoto and asked nicely, for a partial sponsorship.
we've seen a flux in bisimoto exhausts on the forums as of late, and now they only show 3 in stock
MikeyGrz
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Nov 1, 2018 12:12 PM
Nmorfin85
20
Oct 27, 2016 03:01 AM
gd3vbp
Apr 7, 2009 03:15 PM
t3chn0rav3rb0y
16
Mar 28, 2008 03:52 PM
jazzknight
Dec 13, 2007 08:42 PM
