2015 Fits prepare now for larger battery
Old Aug 10, 2018 | 11:24 PM
James Butler's Avatar
SInce my original 51R Fit battery is almost 4 years old I know it will need to be replaced. My 2015 has the so called smaller battery tray that will not take the larger 151R battery without a mod. I decided to do the battery tray mod now so it will be ready when I go to larger battery. Newer fits will take the 151R with no modifications to the tray. I took out my tray and cut off the end so the larger battery will drop in when I need it. Best to be prepared. Picture is of cut off part off my battery tray.
Old Aug 10, 2018 | 11:30 PM
xxryu139xx's Avatar
you have your battery model numbers backwards. the larger battery is the 51r. the smaller battery is the 151r, which is stock to the fit.
Old Aug 11, 2018 | 09:45 AM
Thanks for correction.
James
Old Dec 2, 2018 | 08:51 AM
JazzSus's Avatar
I did replace my 151r original battery with 51r couple weeks ago. I don't think is necessary cut under tray just simply remove it. Is there just to collect dust water and debris anyway We already had few "real" winter frost and I really appreciate bigger cold starting power of 51r
erichyung
Mar 16, 2026 04:11 PM
SevereService
122
Feb 23, 2026 11:03 AM
Jensen Healy
Dec 6, 2019 02:54 PM
dman
Sep 15, 2016 08:39 AM
oshow
Aug 12, 2010 03:19 PM
