Help with Heater control bulb replacement
Old Oct 1, 2018 | 06:26 PM
der Mond's Avatar
Question Help with Heater control bulb replacement
The manual is not clear on how many bulbs are needed of what kind in order to replace the bulbs for the three rotary knobs for temperature, fan and heat/defrost. Has anyone done this? I don't want to remove the whole unit again just to see what bulbs to purchase. Thank you.
Old Oct 1, 2018 | 11:34 PM
ezone's Avatar
https://estore.honda.com/honda/parts...n=&b=B++17&dl=
Bulb #7, (T5), parts catalog says qty 4 in this image
Old Oct 3, 2018 | 03:56 PM
der Mond's Avatar
Thanks, and if you can show me where quantity 4 is listed in the parts catalog, I would appreciate it. I can't find that.
Old Oct 3, 2018 | 05:23 PM
ezone's Avatar
I only found that in the real dealership parts catalog.
Old Oct 4, 2018 | 03:00 AM
der Mond's Avatar
Thanks again...
There is no substitute for dealership input...bulbs on order.
A/C clutch kit should be here for the w/e.
Old Oct 11, 2018 | 06:53 PM
der Mond's Avatar
The light bulbs come with a blue condom - I assume this is to dim them down. I took the condoms off and I have to say I like the nice bright heater control lights for the first time...
Old Oct 12, 2018 | 08:00 AM
GAFIT's Avatar
But, what if they make babies and you end up with more bulbs?
Wonder if the blue was meant to change the color? Either way, glad you are happy with the results!
Where did you order the bulbs from and how hard were they to change?
Old Oct 12, 2018 | 03:49 PM
der Mond's Avatar
I get all my Honda parts from Majestic Honda - aka hondaautomotiveparts.com. Changing the bulbs is a PIA. You need to remove the lower trim piece below the heater knobs (one screw) then get up in there from the bottom with a 5/16 socket and extension and remove two screws that hold the center console in place. A mirror can help depending on how dexterous you are. Then you pull the center panel with stereo out and one by one remove the electrical connectors to the panel, and after removing the glovebox you d/c the three HVAC cables from their destinations so you can pull the center panel out enough to get at the lights, that are twist-locked into the white unit at the bottom. It is really worth it to use the Honda '07-'08 service manual, or alldatadiy.com. for diagrams and step-by-step. Don't try to pry that center panel out, it is held in by the screws and comes out easily once they are out. Good luck.
Old Feb 7, 2019 | 02:00 AM
hortonma's Avatar
Which bulbs did you order and how many? Looking at the parts diagram, was it item #4 or item #7 or a different bulb?
Thanks!
Old Feb 7, 2019 | 06:33 PM
der Mond's Avatar
Bulb
Bulb (T5) (14V 100MA)
79555-SLN-003
This is #7. The diagram on the Honda parts sites, as well as alldatadiy and the Shop Manual, are really weak in showing this. It appears on the top left of the Honda diagrams and shows just one instead of the 4 needed. And the diagram that comes up when you select it is really moronic. The other bulbs are used for the A/C and rear defroster switches. The bulb comes with a blue cover that will provide a mild light for the dial, or you can just peel off the blue as I did; of course it provides a brighter light, then. Good Luck!
Old Feb 7, 2019 | 07:59 PM
hortonma's Avatar
Thank you very much. I used the link you provided to order the 4 bulbs. Very reasonable price AND shipping.
Thanks again,
Mark H
Old Feb 8, 2019 | 12:26 AM
der Mond's Avatar
Glad to hear it. I've used Majestic Honda for years, great folks, good prices and good service.
Old Dec 8, 2024 | 07:16 PM
amyvegan's Avatar
Why so complicated? Grrrr, Honda...any idea how much this will cost at a dealer?
Why so complicated? Grrrr, Honda...any idea how much this will cost at a dealer? Thanks!!!!
Old Dec 11, 2024 | 03:41 PM
der Mond's Avatar
You can bet it will be too much at today's labor prices. But I wouldn't trust anyone else, if you're not up to it, if you have had good results from your dealer thus far
Old Dec 11, 2024 | 03:50 PM
amyvegan's Avatar
Thanks. I'm not taking my car apart. I'm a 62 year old woman with zero training. The big idea is bulbs should be easy to replace and not require the dismantling of the entire console. I was HOPING there was a way to just unclip, pop off the dial mechanism and replace the bulb easily. Stupid design. Thanks.
Old Dec 12, 2024 | 10:40 AM
woof's Avatar
One thing that I've repeatedly heard on YouTube channels is that today's cars are designed to be easy and cheap to assemble in the factory where they are built, but nobody cares about the costs of maintenance - repairs and the like. If it's very difficult to install replacement parts the manufacturer just doesn't care because usually the warranty will be over and it's the customer's problem. Manufacturers now are only looking after number one - themselves. The increased complexity in modern cars makes the situation worse for owners.
Old Dec 13, 2024 | 05:25 PM
amyvegan's Avatar
truth. we need a new brand of car with plug-n-play features for easy replacement of bulbs and fuses (etc) for owners. LOL.
Old Dec 13, 2024 | 06:34 PM
woof's Avatar
But then if if repairs are so easy for the owner to do how is the poor dealer going to make his money?
morgantruce
Sep 1, 2014 12:12 PM
713_fit
Oct 18, 2009 01:06 AM
kamakurakid
Nov 22, 2008 01:31 PM
bestfit
Feb 1, 2008 04:38 PM
Deivioncrx
Jan 8, 2007 03:48 PM
