steel wheels 15 inch
Old Oct 13, 2018 | 09:34 AM
hoibal's Avatar
Hi all,
I'm in the UK and have a 2004 1.4 Fit, and want to upgrade the 14 inch steel wheels to 15 inch
I want to run 195/55 R15, and whilst I know I can just about get these on a 5.5J rim, I wanted to go for the 6J rim from a 2001 Civic so the sizewalls sit better on it.
I found these for sale new and just wanted some opinions to see if they will fit my car:
https://www.oponeo.co.uk/steel-wheel...-1149#18073584
I'd really appreciate any advice you can give!
All the best
Steve
Old Oct 14, 2018 | 09:24 AM
lannym's Avatar
4x100 and 56.1mm hub bore is perfect, same as factory, so the wheels certainly will bolt up nicely.
there is a 6x15 factory option with a et53 offset. the ones you're looking at are et45, so they'll be 8mm further out than the factory setup. also, factory uses 185/55 so your tire will be 11mm larger OD, and also another 5mm outboard..
Old Oct 15, 2018 | 08:27 AM
hoibal's Avatar
nice one thanks mate! much appreciated!
peet1
Dec 1, 2015 06:14 AM
HONDADAZ
Jul 5, 2014 05:08 AM
Saifox
May 2, 2009 12:41 PM
samwell
Apr 27, 2008 08:55 AM
davela72
Mar 10, 2008 06:35 PM
