Replace pre-emptively?
Old Oct 23, 2018 | 10:42 AM
OrangeSport09's Avatar
Hi All,
I have a '09 Honda Fit with 212k miles (about 25k/year). Honda has recommended they change out the water pump and serpentine belt as part of the 200k maintenance. Necessary or no?
Thanks!
Old Oct 23, 2018 | 11:25 AM
GAFIT's Avatar
FWIW, I think 100k is a good time to change the belt. So, if it hasn't been done in the last 100k miles, I'd have them change it.
I've never changed a water pump before it failed (except for when I was doing a motor out rebuild), but I can see why they are recommending the replacement. It could fail at a bad time and the motor could, potentially, overheat. I would base the yes/no on the water pump based on the quote to replace. If it's like $100, I'd probably have them change it. If it's like $300, I'd skip it.
Old Oct 23, 2018 | 12:01 PM
Thanks! When you are talking about price, you are just including labor, correct? I need to go back and look - they said $750 for water pump, serpentine belt, and spark plugs .
Old Oct 23, 2018 | 12:30 PM
GAFIT's Avatar
Yes, I was including labor.
That is a ton of money! Since your car is well out of warranty, you may want to find an independent import shop for the service. Yelp and Google reviews can help you find someone good in your area.
Old Oct 23, 2018 | 12:53 PM
julianachos's Avatar
I'm currently almost 500k on the original water pump. Will probably replace it after the 500k mark though.
If it doesn't add much to the bill, it wouldn't hurt.
Old Oct 24, 2018 | 12:15 PM
500k, nice!
Sloppy_Snood
Nov 2, 2023 12:42 PM
spin out
Jun 22, 2019 11:59 PM
lcmon
Jul 28, 2005 01:31 AM
Kenny
May 4, 2005 04:44 PM
mpet500
May 4, 2005 11:16 AM
