I wonder if the 6 speed manual can be replace with the factory 5 speed manual
Old Nov 5, 2018 | 02:38 PM
Rodney Balines Lopez's Avatar
I wonder if i can transfer the 6 speed manual for the 5 speed manual
Old Nov 5, 2018 | 03:00 PM
GAFIT's Avatar
I would think that it's possible in theory. Biggest question would be why? The 6-speed is only different between 4-6 with it's 6th being the same as our 5th.
I'd like better gearing, but the GK's 6-speed isn't really better for most uses.
Old Nov 5, 2018 | 04:24 PM
evilchargerfan's Avatar
just curious... OP .... have you ever test driven a gk5 6 spd?
and ... if yes.... what are your thoughts on cruising at highway speeds while in 6th gear?
Old Nov 5, 2018 | 04:46 PM
Reply
No but im going in 5th @ 65-70 mph @3,500
Old Nov 5, 2018 | 04:47 PM
Reply
I feel like i need another gear
Old Nov 5, 2018 | 04:58 PM
GAFIT's Avatar
The 6-speed will not give you a gear on top of our 5th. It has the exact same overdrive. In other words, exact same rpm at highway speeds.
You'll just be doing more shifting with the same end result.
Swapping to the final drive from a Civic Hybrid is, in theory, possible, but doubtful that it's a good move either. We're kind of stuck with bad first and fifth gear ratios as far as I know.
Old Nov 5, 2018 | 05:37 PM
6th gear on a GK5 will leave you in the same rpm's sadly
Old Nov 23, 2018 | 08:19 AM
Snow tires
Hey guys I just wanted to know if I can use the springs form an cr v to lift it just enough for my snow tires 205/60R15 Blizzak WS60
Old Nov 23, 2018 | 12:34 PM
daiheadjai's Avatar
Getting yourself a taller wheel/tire combo might be a better solution to solving buzzy cruising rpms.
Of course, you will likely also see worse acceleration....
Old Nov 25, 2018 | 08:34 AM
knope's Avatar
The 5speed from which factory generation/model? None of this thread means anything without model numbers.
Old Nov 26, 2018 | 05:29 PM
wait are we talking tires/springs .... or transmissions?
(I'm so confused)
Old Nov 26, 2018 | 06:13 PM
daiheadjai's Avatar
The OP had mentioned he didn't like the buzzy/high RPM cruising in 5th gear... But since the 6th gear is at the same ratio as the 5th gear of the 5-speed, that won't help.
An alternative way to get taller gearing (and thus lower RPMs when cruising) is to opt for a bigger circumference wheel/tire combo to "mimic" a taller gear ratio.
But yes, the original question was about transmissions!
Old Oct 27, 2020 | 01:41 PM
DaBinChe's Avatar
I used to complained about the gearing too and thought 6th needed to be taller. But now that i have had the car for almost 6years it is just about right. When you are by yourself in the flats it seems too short. But once you load up to capacity and in the mountains you are glad the gears are short. Hell even on the flats with 5people in the car it has a hard time.
justus
Jan 11, 2019 11:40 AM
Fitftw15
Sep 1, 2017 07:45 AM
Canoehead
Apr 25, 2014 10:20 PM
avosfit
26
Jan 9, 2014 09:36 AM
fr_wilson
Apr 2, 2009 02:26 PM
