3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
tanabe strut tower brace
Old Nov 28, 2018 | 07:33 PM
bill bosco's Avatar
was reading some posts on the tanabe tower brace from a while back . the last post mentioned that it appeared that the mounting plate now blocked
access to the fuse box cover , can anyone verify this ?.if that's the case , it does'nt sound like a very practical mod
Old Dec 2, 2018 | 02:46 PM
Action Jackson's Avatar
Yup. It does block the fuse cover. Takes me a few minutes to remove that side of the brace to access the fuses.
Old Dec 2, 2018 | 04:14 PM
bill bosco's Avatar
thanks for the heads -up , looking at the pictures i still can't figure out what it's attached to . so far , i've got 2 subframe braces under the front and
2 braces in the back ( one across the bottom in front of the beam axle and the other across the rear upper seatbelt mounts ) they work wonders
for the feel of the car
Old Dec 6, 2018 | 03:44 AM
USDM's Avatar
Save your money and spend it on a Progress rear anti-sway bar instead of the Tanabe strut bar. It's a much better, and effective, mod.
Old Dec 6, 2018 | 08:03 PM
bill bosco's Avatar
yes , i have one , was my first mod
Old Dec 7, 2018 | 03:22 PM
evilchargerfan's Avatar
so that said, front sway bar next?
Old Dec 8, 2018 | 09:18 AM
i would pass on the rear sway bar (makes your car drive like 2 separate pieces) and start with the front sway bar on the Fits. the car leans too much and loses posture while turning. then get a LSD.
Old Dec 8, 2018 | 08:01 PM
bill bosco's Avatar
i have a blox swaybar for the front ,but haven't put it in in yet , pretty much looks like i have to drop the subframe to get it in so right now it's winter and i'm not in a rush .
it probably would make a big difference i'm sure .and no , the car doesn't loose it's posture while turning , it's rather composed , i'd say . the braces on the car do alot for
roll stiffness
Old Jan 15, 2019 | 03:30 PM
USDM's Avatar
It's an FF car. If you want to make it rotate "better," you'll want to stiffen up the rear end.
Old Jan 15, 2019 | 04:27 PM
roll stiffness
pics of that front "sway bar" please?
Old Jan 30, 2019 | 05:00 PM
Mee Boc's Avatar
Definitely this. Even with traction control off, it's tough to get to slide around tight corners.
Old Jan 30, 2019 | 05:15 PM
sttill waiting for pics of that front sway bar ....
Old Oct 11, 2019 | 07:25 PM
bill bosco's Avatar
been looking at the various pictures of the tanabe tower brace , so , you really do have to undo the mounting bracket to access the fusebox ?
Old Oct 12, 2019 | 03:01 AM
Absolutely.
Old Oct 12, 2019 | 03:24 PM
TougeMonster_GK5's Avatar
just re-installed mine last night after getting the car back from the shop. If you can see on the driver side, the bracket is blocking entry to the fuse box. Not a big deal to remove if need be! So go buy it! 😎
Old Feb 5, 2021 | 05:55 PM
blanka98's Avatar
Bringing this back from the dead.....just bought one and just figured out that this bar mounts to the thin sheet metal.....I'm quite disappointed at Tanabe. This will provide only looks over anything....
Old Feb 7, 2021 | 03:31 AM
JingJangJoe's Avatar
that's right. The front strut bar does nothing practical at all.
Old Feb 7, 2021 | 09:56 PM
NWCH's Avatar
I like mine.
Old Feb 7, 2021 | 09:57 PM
NWCH's Avatar
There is a matching lower front brace also. It's on my future purchase list.
https://www.ebay.com/itm/TANABE-SUST...53.m1438.l2649
Old Feb 7, 2021 | 10:03 PM
NWCH's Avatar
What it looks like installed.
Jz1219
Sep 10, 2012 11:29 PM
jt.wilson89
Jun 24, 2009 12:06 AM
Will I Am fit.
SoCal Classifieds
14
Feb 12, 2009 09:43 PM
fit4kris
Tanabe Racing Development USA
17
Oct 16, 2007 12:19 AM
fit4kris
Apr 14, 2007 04:00 PM
