My Maintenance Diary
Old Dec 5, 2018 | 03:19 PM
evilchargerfan's Avatar
Post GK5 Maintenance Diary
* MODS - If this is in the wrong location, please move *
I figured I'd start a diary/log of my maintenance. Partly so I can keep track of my own stuff, but also to share with others what has been done, and at what mileage
23,500 mi
04/2018 = Purchased the car
24,000 mi
05/11/2018 = K&N Engine Air Filter
05/11/2018 = K&N Cabin Air Filter
28,500 mi
06/27/2018 = Tires (Hankook Ventus V2 Concept 2 H457 195/50 R15)
30,000 mi
07/08/2018 = Oil Change + Bottle Of Techron Fuel Inj Cleaner
32,500 mi
08/05/2018 = Stock Air Box Removed (end k&n engine air filter)
08/05/2018 = Weapon R Intake Installed
08/05/2018 = Oil Catch Can
34,500 mi
09/30/2018 = Bottle Of Techron Fuel Inj Cleaner
35,000 mi
10/09/2018 = Tein Coilovers
37,500 mi
11/06/2018 = Oil Change + Toe Alignment + Rotate Tires
40,000 miles
12/08/2018 = a bottle of techron + new brake pads/calipers/rotors and ss lines
Old Dec 5, 2018 | 03:20 PM
Planned:
Next Tire Rotation + Re Grease End Links = 75k
Next Oil Change = 80K
Next Techron Bottle = 80k
Next Cabin Air Filter Cleaning = 84k
Next Intake Filter Cleaning = 84k
Next Set Of Tires = 90K
Next Brake Fluid Bleed = 12/2020 or 100k
Next Valve Adjustment = ?
Next Trans Fluid = ?
Next Coolant Replacement = ?
Next Spark Plugs Replace = ?
Re Tighten Spark Plugs = ?
Old Dec 5, 2018 | 03:48 PM
* * * RESERVED * * *
Btw, suggestions/input are welcome
Old Dec 6, 2018 | 01:39 PM
marmaladedad's Avatar
Are you also keeping tabs on whether the fuel efficiency of the Fit is changing before/after your maintenance? For example, steady decline in MPG, changed air filter, MPG at xx.x.
Old Dec 6, 2018 | 02:00 PM
yes and no. not in depth to the tune of "replaced engine air filter, mpg increased to X" .... BUT .... when I do my fuelly logs, I do put notes in there. also, when/if I see big dips in mpg, I immediately would notice and take action if needed.
if I make a change that increased mpg, I try my best to share. Example .... lighter wheels + tires + higher psi = mpg increase. or, roof vortex generators = no mpg change. etc etc.
2015 Honda Fit (Honda Fit) | Fuelly
Old Dec 6, 2018 | 02:39 PM
Ahh, yes, Fuelly. I should utilize that to help me keep track. I am happy whenever I get north of 30 in the Fit - the other two (MDX, Odyssey) average 28mpg....downhill!
Old Dec 10, 2018 | 03:04 PM
12/08/2018 - 40k miles:
-dumped a bottle of techron
-new brake pads/calipers/rotors and ss lines
Old Dec 10, 2018 | 06:25 PM
GAFIT's Avatar
I hadn't realized that you put a sad Fit back on the road. Was it previously totaled? Nice work getting it back on the road.
That first picture is almost comical. It looks like a bomb went off inside the car and blew the doors, bumper, etc off. Funny and sad at the same time.
Old Dec 10, 2018 | 06:43 PM
it is indeed, salvage title. a few things I avoid if/when I buy such a car:
-deployed air bags
-water/flood related damage
-anything that touched the motor
-frame damage (non repairable)
in this case, it was just the right amount of damage .... in teh right amount of non critical areas ... to put the bill over a certain total .... which results in a "total loss". IIRC, alot of insurance companies will total out a car if you go over 75% of acv (here in CA anyway)
funny story, my prev car (lexus ct) was 5% away from being "a total loss" by virtue of simple rear ender, which did not deploy air bags .... of the near 20k in damages... a crap ton of it was just labor alone
Old Dec 12, 2018 | 08:01 PM
huh, i didnt know it was a salvaged car. i did notice earlier on that the silver paint wasnt consistent on the doors but didnt think too much of it. thought maybe a small fender bender watever. GJ on the car.
Old Apr 4, 2019 | 01:53 PM
03/21/2019 = 45892 = new coolant (after accident)
04/03/2019 - 47000 = rotate tires (directional tires, left front to left rears -> left rears to left front..... same side, no criss crossing)
04/03/2019 = 47172 = t rev
Old Apr 7, 2019 | 09:49 PM
04/06/2019 - Oil Change + Dumped Out Oil Catch Can, 47500 miles
Oil = Mobil 1 0w-20, Extended Performance, High Mileage Formula
Filter = Purolator "BOSS"
(Both Items Rated for 15k)
Catch Can At About 30ml factoring residue stuck in the steel wool ball, and a little bit left in the can itself
Old Apr 7, 2019 | 09:51 PM
04/07/2019 - Cleaned K&N Cabin Air Filter, 48k
04/07/2019 - Cleaned K&N Engine Air Filter, 48k
Old May 6, 2019 | 02:03 PM
05/05/2019 - 50k miles:
Old May 13, 2019 | 03:44 PM
05/11/2019 - 51k = Re Greased Moog "Problem Solver" End Links
05/11/2019 - 51k = rotate tires (directional tires, left front to left rears -> left rears to left front..... same side, no criss crossing)
NOTE:
EARLY to the rotation this go around .... this was due to loss of traction, in wet conditions. I noticed the fronts have much less tread compared to the rears, and this will more than likely be the last rotation, until a brand new set of tires are purchased in the near future.
Old Jul 8, 2019 | 10:23 AM
07/07/2019 - Cleaned K&N Cabin Air Filter, 60k
07/07/2019 - Cleaned K&N Engine Air Filter, 60k
07/07/2019 - dumped in a bottle of techron, 60k
Old Jul 8, 2019 | 10:36 AM
07/07/2019 - Oil Change + Dumped Out Oil Catch Can, 60000 miles
Oil = Mobil 1 0w-20, High Mileage Formula
Filter = Purolator PL14610
Catch Can Was FULL, I was able to measure 175ml! (who knows how much excess overflowed from can, into the intake mani)
Old Jul 8, 2019 | 10:48 AM
07/07/2019 - 60k
Achilles ATR Sport Tires 195/50/15 (heavier than prev tires, and more meaty/taller side wall, even tho same specs. had a neg impact on mpg)
Old Jul 8, 2019 | 03:44 PM
07/07/2019 - 60k
Was the trade-off better handling?
Old Jul 8, 2019 | 04:49 PM
it was unintended. when I made the purchase, I assumed it'd all be the same. I was super wrong
pros:
-less noise / more comfy ride
-cost, $45 a tire
cons:
-bad mpg
