Stereo install help wanted in Orange County
Old Feb 14, 2013 | 02:11 AM
FightingChance's Avatar
Hi, I've picked up a Sony single DIN deck and have the Scoche kit, honda harness and a Sony harness. Rather than research how this all goes together, if someone with some experience could lend a hand I'm sure we could get it done much faster. I live in Newport Beach, can come to you. Fine Biers or some bucks as payment, negotiable. Thanks.
Old Feb 14, 2013 | 01:56 PM
vinn's Avatar
mmmm fine bier. wish I had time to help ya but GL! shouldn't be too hard though!
Old Feb 14, 2013 | 07:34 PM
gimme's Avatar
Master FitFreaker
super simple. color coding is your best friend. mate the sony harness with the honda aftermarket harness wuth either butt connectors or solder/heaat shrink, plug s harness into stereo and h harness to the h harness and badabing, done!
Old Feb 14, 2013 | 08:05 PM
Most colors between the harnesses match but some do not. Some leads are taped together for some reason. One of the Sony leads has a tap in it. The antenna lead has an extra wire, I'm not sure where that goes on the unit. Etc. If all the colors matched I wouldn't feel too apprehensive about it.
I got the Honda side of the harness from another user on here that was planning on doing a stereo swap but never did, so I only have his word that it is a Fit harness. I guess I'd better go look it up.
Old Feb 14, 2013 | 10:14 PM
gimme's Avatar
Master FitFreaker
hrmm...I sure wish I had extra time or I'd help "/
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Red
Car Stereo Power Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Light Green/Black
Left Front Speaker Negative Wire (-): Light Green
Right Front Speaker Positive Wire (+): Green/Yellow
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/White
Left Rear Speaker Negative Wire (-): Blue/Black
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue/Yellow
Old Feb 15, 2013 | 03:39 AM
The Sony harness has a red wire, but the Fit harness has a red and an orange wire. There's a couple other mismatches. What the leads go to doesn't help.
Old Feb 16, 2013 | 11:49 PM
Paid a dude on CL to do it, turned out okay (forgot the metal fitting cage but we made it work without it.) Scoche almost fits flush with the dash. Mods you can lock or delete this thread.
StewMJC
Oct 4, 2018 12:41 PM
delviper
Fit I.C.E.
Oct 17, 2013 10:29 PM
clay7160
Jul 31, 2011 12:16 PM
CBP
Aug 12, 2008 04:27 AM
tluvz4
May 4, 2005 04:44 PM
