Shelf Life of Brake Fluid
Old Apr 22, 2023 | 07:42 PM
Mister Coffee's Avatar
I just found four bottles of Honda Dot 3 brake fluid in a box in my apartment. I'm not going to use them because I don't trust that the fluid is still good.
This site says unopened bottles of brake fluid should be good for 2 to 5 years. Question: Why don't I believe what I read on the Internet. Answer: I don't know.
By the way, over time, the bottles collapse.
Old Apr 22, 2023 | 09:02 PM
GrE8_Fit's Avatar
From what I've gathered over the years, DOT fluid absorbs water from the air. I'd bet that your bottle is still fine, but a new bottle is affordable enough.
Old Apr 23, 2023 | 12:58 PM
Agreed. And you are correct. Brake fluid is hygroscopic. Any exposure too air and it will absorb moisture.
Old Apr 23, 2023 | 04:05 PM
woof's Avatar
You can buy a cheap "brake fluid tester pen" from Amazon which will tell you what the water content of your brake fluid is. Note that after using such a pen you have to clean off any brake fluid residue because brake fluid will destroy the plastic on these devices. This is a handy thing to have although not something that you would use a lot.
Old Apr 26, 2023 | 09:11 AM
NWCH's Avatar
The fluid will be fine if the bottles are sealed. I have never seen a sell by date on brake fluid bottles.
Limmie
Jul 16, 2023 02:27 PM
jwb671
Jul 22, 2020 11:01 PM
fitowner10
Sep 9, 2014 08:36 PM
InSaNehb
Jun 24, 2011 10:54 AM
AppleMac*Fit
Nov 14, 2010 01:40 PM
