DIY Transmission Fluid Change
#41
For auto I believe you have to do a "flush". Drain and fill changes only a portion of the total. I don't have a auto fit but from what I practice in my other auto, auto is even more demanding on the fluid and it should be changed every 30k at least. Check the owner manual for auto change interval.
#47
~Robert
#49
- Tim
#51
Okay thanks. That's what I was gonna do. I was thinking maybe there are other transmission fluid that is recommended by fit owners that I can get from places like Autozone or similar stores.
#52
If you have a Honda or Acura dealer nearby, it's easier just to use the OE stuff. That's what I do.
MTF is a delicate mixture of slippery and not-so-slippery fluids (friction modifiers).
Yes, it is desirable to use the most slippery liquid possible, this promotes those buttery smooth shifts. It should be high-pressure enough not to be squeezed out from between the gear surfaces. This prevents gearbox wear and keeps temps cool inside the 'box.
But, the synchronizers (the things that prevent gear "crunch" when shifting) need some friction or they can't do their job.
That is why Honda, GM, Amsoil, and Redline (probably others) have concocted special blends just for manual gearboxes.
Hope my "layman's descriptions" of gear oil properties haven't insulted you. There are explanations of properties on the Amsoil and Redline websites that are more technical.
#53
Not to bring this up from the dead but...I notice that in the OP's DIY it says you need to jack up the driver's side but then later that it should be on level ground to check the fluid level. So...at what point in the procedure do you let the car back down to be on level ground?
#54
just put the car on jack stands. makes it easier and it will be level
the whole time.
#56
DOing it this weekend!!
I'm about to do my MTF oil change this weekend, I'll be at 50k hopefully by this Sunday so I think it's perfect timing!
Luckily I have 3 quarts of Honda MTF laying around so I'll just use that.
#58
just finished
I just finished my tranny oil, engine oil, and I even cleaned and re-oiled my KN filter.
Did anyone notice that the tranny drain and fill bolts were kinda loose? When I put my wrench on them, the popped right off with a little pressure. I made sure to torque them down to 35 ft/lbs just to get the crush washer to crush!
Kinda weird how the tranny only took like 1.6 quarts of Honda MTF before it started coming out of the fill hole.
I used jack stands to level the Fit and I custom made a filler with 2 clear tubes and a long funnel. Had my wife pour the MTF from the top of the engine and I was under the Fit ready to plug up the fill hole, it worked like a charm.
#59
Whats wrong with doing this
When changing tranny oil whats wrong with putting same amount of oil you take out back in with the new oil and also why not use the hole where the dipstick is to put the new oil back in. Then just for sure measure you check level like you should with dipstick to make sure its back at proper level.
