Problem, check engine light blinking between 2000 and 3000rpms.
Old Jan 20, 2016 | 11:19 AM
dwtaylorpdx's Avatar
Originally Posted by snip
Could be coils, spark plugs, fuel pressure regulator, fuel pump, egr valve, any of the dozens of sensors (tps, crankshaft position, map, maf, O2). Could indeed be an exhaust issue but very unlikely since your problem began suddenly.
Have various tests performed including thorough visual inspection to diagnose and correct the problem.
Don't put any snake fluids in it and don't throw parts at it guessing what it could be.
Cats fail suddenly all the time, heck I've had 2 do it, Jeeps had horrible problems with this in the mid 90's driving down the road and pop thunk no power..
Not all additives are snake oil, Sea foam is like almost a hundred years old and boat owners use it religiously to prevent water separation in the fuel. The key is don't think more is better. Use it as the directions tell you.. It will raise your exhaust temps about 150 degrees because it has some pretty good solvents in it.
Techron is another one that is effective at getting water out of the tank, and its recommended by Porsche, Ferrari, Bmw etc.. If you got a really big load of wet gas an additive won't help, IE like a gallon of water in the tank.
Assuming you've eliminated engine sensors,,, and you really think its the fuel...
Most engines have a fuel pressure test port on the fuel rail, and most fuel pressure gauges for EFI have a pressure release valve, one way to empty a tank is to attache the gauge, open the vent with the hose in a fuel can , pull the fuel pump relay and connect a wire from the battery to the fuel pump connection on the relay, use the pump to empty the tank. Worst case you need two 5 gal cans.
Be aware that if you got a load of fuel that is that bad, the in tank strainer can get fouled as well, so once a fresh can of fuel is in there if its acting like it can't run above idle it could need a new strainer and or fuel filter.
Old Jan 20, 2016 | 11:20 AM
Lehuber89's Avatar
Update:
Originally Posted by doctor J
OP needs to get the OBD-II code; it most likely failure of the rocker arm oil pressure switch that controls operation of the valve lift at high RPM.
Anyone suggested checking the muffler bearing for drag??
My mechanic checked it out, ran all kinds of tests/diagnostics and found nothing. Spark plugs, O2 sensors, c-packs are all new. The catalytic converter is not clogged (But that does not mean that it may not be bad. It WAS in Florida until about 4 years ago, so I wonder how much the salty sea air erroded things). However, the car still does it between 3-4k/rpm. I can get up to speed as long as I keep it below 3k/rpm. My check engine light, just at this very moment, came on, but is no longer flashing. It also just jerked a little when it shifted.
He is thinking that it may need a lash adjustment. Other than that, he's at a loss (I've never seen him at a loss). Any other suggestions?
-Laura
Old Jan 20, 2016 | 12:09 PM
If it has more than 80K since the last valve adjustment it needs done anyway..
Old Jan 21, 2016 | 09:00 AM
Carbuff2's Avatar
Were coil packs the ones recommended? (OEM or Hitachi part # ending in 053)
Also if you say parts are new, when were they put in? (Time and miles)
Many times (especially with the cheaper aftermarket coils) they start to malfunction a few thou' down the road.
PS, X2 on the valve lash...
fitzharris
Nov 21, 2021 11:42 AM
Tomdangg
Oct 19, 2016 07:40 AM
TrippKnightly
Jan 9, 2013 12:48 AM
mrpooh
Nov 8, 2012 10:50 AM
ny111
Sep 6, 2010 11:44 PM
