Any DIY on how to replace the parking light?
Front Parking/Side marker Light
1. Disconnect the 2P connector from the front
parking/side marker light.
2. Turn the bulb socket 45 ° counterclockwise to
remove the bulb from the headlight housing.
3. Install a new bulb in the reverse order of removal
Thanks Black3sr. Okay I will try that. I asked because I was trying it when I purchased the bulb but I had a hard time turning the old bulb housing. I was wondering if there's a better way of doing it.
hkfooey
Mar 2, 2011 05:53 PM
