DIY Roll Center Adjusters help?
Old Dec 14, 2012 | 01:13 AM
jdmgd4's Avatar
hi all, i just received my RCA's from Buddyclub and was wondering is it hard to install these? any special tools needed? anyone have a DIY guide i can follow?
Old Dec 14, 2012 | 12:23 PM
Wafulz's Avatar
<3 i wanna get the RCA to probably in January and u gotta press the old ones out to put the buddys on u can rent the tool at any auto store or take it to get done by a shop should not be that much
Old Dec 14, 2012 | 01:01 PM
TPColgett's Avatar
Hmm... At least on a GD this can be a difficult job. It's easy to crack/bend the LCA when trying to press out/in the RCA... Not to mention this will typically require a shop press. I would highly recommend taking this to a shop who has experience doing this...
Also, what was your reason for going with RCA's? Are you low enough that your encountering bad bump steer? I looked into them, and they were cost prohibitive, and since I'm not very low and not experiencing any major bump steer I opted to add camber and stickier tires
specboy
23
Aug 14, 2022 01:32 PM
doctor J
Nov 3, 2017 12:26 PM
pwnstar
Fit I.C.E.
May 8, 2014 04:42 PM
vinnymac
Oct 31, 2010 10:22 PM
kamakurakid
Feb 19, 2009 12:00 PM
