Coil packs removal
Coil packs removal
Hi I am new here. My FIT is misfiring, and after some research I wanted to try and check the coil packs, however it seems pretty impossible to access the back of the engine. what is the best procedure to do this? my thoughts are, removing the plastic trim that is directly under the hood. any suggestions please?
thanks
thanks
Hi
On a 2007-2008 fit, theres no need to remove anything, just take a small rachet with a 10 mm head and a extension and you should have enough room to acess the coil pack bolt. Its really easy to do. Im waiting after the part to change mine, this car is not fun to drive with missfire!
Hi
Easy. You do know you posted in 1st gen forum. The 1st generation fit had a long run starting everywhere but in the USA in 2001. It finally arrived here in 07 to 08. You got the best model of 1st generation because of extra things like TPMS and other little things. Tips and awesome platform to mod on a budget. PM me if you like.
it's a 2008, but space seems really limited. you cannot actually see what you are doing, can you?
You are a GD3.
You do not have to remove anything to gain access to the coil packs.
I strongly suggest you use an extension for your ratchet. Approach your car from the side and look, you will see the 4 bolts holding in each coil pack. One for each. It is a little tight but extremely easy to do and is not as tight as you think. This should take you no more than 15 minutes to take out and replace all 4.
You are a GD3.
thanks for the great info, i shall give it a try in the morning.
Remember, your coil packs are on the back side of the motor. Not under the plastic motor cover you had mentioned earlier.
You will see all 4 coil packs closest to the firewall of the vehicle on the backside of the motor.
the plastic that I mentioned, I meant the plastic that lies just under the hood, the one that covers the wiper motors, that's why I said it's so tight. mine has an I-Vtec engine
There is no need.
spark replacement done. I went ahead and removed the plastic trim and the wiper motor assembly right from the start. I figured an extra 15 mins were well worth the time, for the extra space that I gained. Changed the plugs to 'Denso' as I could not find 'NGK' replacement. seems to be working fine now.
I do not think there was a coil problem cause the loss in power only occurred while accelerating and not while idling. only time will tell
thank you all for the help.
It should gradually get worse in the next 1-2 years.
warning
If you car is miss firing don't keep driving it. Why?, Well mine started miss firing during this past winter. I order replacement coil packs which took about 5 days to get then I waited a few more day until it warmed up to about 25F to change the coils. By this time mine was miss firing quite a bit. At that point it set an engine code which turned out to be O2 sensor code.Well It ended up clogging the O2 sensor ruining it. I had to replace the front O2 sensor too. that was another 135 bucks down the drain. There is a thread on my problem some were here.
Mtwalenciak
Dec 23, 2014 10:04 AM
