Fujita Short Ram Intakes (Pics)
Old Apr 21, 2007 | 03:37 PM
fitoromocto's Avatar
MERLYNMUZIK some pics please
Originally Posted by MERLYNMUZIK
i fabricated a heat shield for the sri and bolted it to the right stock airbox mount. 15 minute job...no extra heat.
Could you post some pic from your heat shield that you fabricated would be much appreciated
Old Apr 21, 2007 | 04:28 PM
MERLYNMUZIK's Avatar
i'll try to post them sunday night after our NY fit meet...i should have some good pics then!
Old Apr 22, 2007 | 09:09 PM
as promised
i fabricated it from two aluminum pans and bolted it to the stock airbox mount
Old Apr 23, 2007 | 05:52 PM
Thank you i be doing the same hope to receive my SRI by the weekend from the comment read I should be please.
Old Apr 23, 2007 | 11:02 PM
rekcah's Avatar
I installed mine about a month ago and also pissed fluid all over the ground. In fact I drove my other car to get fluid afterwards. Directions were ok but it should say warning you are about to get radiator fluid everywhere. I love it and feel some extra power when I merge on the freeway. I am a Sport AT. To compare here is both and after but not the same day.
Old Apr 24, 2007 | 08:21 PM
kurtdesch's Avatar
I have this intake too, does any one have a problem with their hoods not closing all the way?
Old Apr 24, 2007 | 08:30 PM
rekcah's Avatar
No but It is rubbing a little.
Old Jun 7, 2007 | 10:50 PM
sparkedfire's Avatar
Where did you guys purchase your SRI from? Can I just get it from the Fujita online store?
Old Jun 7, 2007 | 11:12 PM
boyetssilverfit's Avatar
yes,you can buy them directly,good customer service.
Old Jun 9, 2007 | 12:43 AM
Thanks,
I am a little concerned about the intake rubbing with the hood as mentioned above. Anyone have comments on that?
Thanks again.
Old Jun 9, 2007 | 01:03 PM
i personally dont have any problems with my hood. i have a manual-dont if that makes a difference. i just put it together real loose at first and then tightened everything evenly.
Old Jun 9, 2007 | 01:12 PM
  #32
me too,i dont have any problems with my hood rubbing on the intake nor my intake interfering with the closing & opening on the hood,i love this intake man,by the way i have AT so i install the SRI,
Old Jun 9, 2007 | 11:09 PM
  #33
heres mine,i did my first coat today,i used ceramic thermal barrier coating paint,sorry a little crappy coating,i'll do some touch up tomorrow,
Old Jun 9, 2007 | 11:11 PM
  #34
Old Jun 10, 2007 | 01:08 AM
  #35
Thanks guys. I guess I'll be grabbing me one of these pretty soon.
Old Jun 10, 2007 | 01:39 AM
  #36
youre welcome!
Old Jun 17, 2007 | 04:35 PM
  #37
jojabis's Avatar
Okay so picked mine up friday and we got it installed yesterday morning. It bothered me that it sat u so high so I took out the lower air box mount and flipped the vibration mount so it was pointing down, the whole unit sits an inch lower.
Old Jun 18, 2007 | 08:36 PM
  #38
ldweng's Avatar
Sounds interesting. Could you post a photo? I am having trouble understanding how you did that.
Old Jun 21, 2007 | 04:36 PM
  #39
jojabis's Avatar
I think you were asking me...
I'll snap a pic and upload it. Trying to explain better with words, the bracket is and L bracket that is mounted onto the rods that hold the battery, instead of mounting it like this L I put it in this way 7 but when I was able to get the arm an inch or lower the filter would touch/rub or the black airbox bracket, so we removed it and the filter now has plenty of room.
here it the flipped vibe bracket
here are the the 2 bolts that the mount was attached to in the upper left you can see the radiator hose guide
Old Jun 21, 2007 | 07:44 PM
  #40
ldweng's Avatar
Thanks,
That clears it up.
