Rev Ignite, more ignition!!!
Old Jan 31, 2007 | 09:02 PM
Goldenboy's Avatar
You might like to check out the, super spec cable. I was using the Ignite Rev and after trying out the cable, I never take it off my ride. My choice is still the Super Spec Cable
Old Jan 31, 2007 | 09:48 PM
Jimmy101's Avatar
What exactly is the super spec?
Is that a grounding wire???
Old Jan 31, 2007 | 11:38 PM
Goldenboy's Avatar
Well its something that works like the ignite rev but this is a more complete setup and it gives better combustion. You can check it out from the TM Works website
Old Feb 1, 2007 | 11:16 AM
gettinafit's Avatar
It looks like ground and a coil for each coil. I don't understand japanese, so that's my guess....
Old Feb 1, 2007 | 08:23 PM
Goldenboy's Avatar
Anyway I am from Singapore and I am using the Super Spec Cable. I was using th ignite rev before. I sure can feel the difference between the two.
Old Feb 3, 2007 | 07:30 AM
jrovic's Avatar
Hey Goldenboy, how much did you get your Super Spec Cable? I suppose you got it Singapore, right? Can I get the shop's name too? Thanks
Old Feb 3, 2007 | 11:15 PM
Jimmy101's Avatar
Imperial Concepts.
Old Feb 4, 2007 | 08:27 PM
Goldenboy's Avatar
I got it imported from Japan myself, from TM Works. I will be cheaper if you get direct from Japan.
Old Feb 4, 2007 | 08:29 PM
Goldenboy's Avatar
Imperial Concepts on have Rev Ignite and it is retailing for about S$350+, if I am not wrong
Old Feb 5, 2007 | 09:34 AM
jrovic's Avatar
Thanks for the info! My contact in Japan cant hook up with tm works. Does imperial concepts have super spec cable? cant seem to find it in their website...
Old Feb 5, 2007 | 09:45 PM
Goldenboy's Avatar
Imperial Concepts do not carry them. I guess you only can find it in the TM Works website. Le me know if you need more infor
Old Feb 6, 2007 | 06:43 AM
  #32
jrovic's Avatar
tm work's website is japanese.I cant read jap.. Maybe you can give an address, contact number and part number for the cable.. Thanks
Old Dec 20, 2007 | 02:42 PM
  #33
Mercurio's Avatar
super spec
i'm from sg too. where did u get it installed? ur preferred w/s?
hkjazz
Nov 23, 2010 07:13 PM
fANTOM
Oct 24, 2008 08:58 AM
fANTOM
Oct 24, 2008 08:42 AM
tonyd3773
Feb 9, 2008 12:03 PM
virtualchuta
Jan 13, 2006 07:11 PM
