Install location for Boost Gauges! Let's See Em!
Thanks for the information. Would you happen to have any more pics of the pod, maybe off the car or something?
There is actually no need to drill holes in the dash. Look closely at my posted photo and you can see that I just put some shrink sleeve over the wires and ran them over to the Dash "Hood". You can cut a very small notch in the bottom of the dash hood and run the wires in there. It really takes just a very small notch because there is some slight clearance below the dash hood. this way no holes in the dash if you decide to sell the fit without the gauge pod.
It really depends what gauges you use. With These K's gauges, theres far to many wires to just hide. These gauges also dont just come with a wire to tap to get a reading as they come with actual sensors that you have to cut open the hoses for, put the sensor inbetween and fix back up.
yea its actually more for me, i got all 3 gauges for about 200. Does anybody know when H-Fit is going to release their similar gauge pod and/or how much it will cost? i emailed them but no response yet...
What brand of the gauges that you got??
Anyone install one of these yet or have an opinion on these versus the analog gauge? I am also wondering how much real use of the analog gauge one can get if the boost is only 5psi? Seems like a big gauge that won't really move much. Is it possible to get an analog gauge with a 10psi scale?
Prosport competition 52mm gauges. From left to right, oil pressure, oil temperature, water temperature.
Video link of them in action:
YouTube - 2007 Honda Fit Prosport Gauges
I bought Autometer Cobalt gauges - boost/vac up to 20psi, full sweep oil pressure, and A/F. Bought em at a local store where i frequently do business. Picked em up yesterday, all brand new in boxes for ~$205 incl. tax. Also bought the metra dash kit and im waiting for best buy to get in the new kenwood double din touch screen
I forget what its called. Its not out yet, I know a guy @ best buy, hes gonna call me when they get it in. I'll see if i can lok it up and let you know.
Hey Sumo,
I like your install and I will be installing some gauges using the same pod in a few weeks. Would you mind telling me where you drilled your dash and if anything needed to be removed to get the wires to snake through to the ground.
I would hate to drill the dash and find that I've just drilled into an air vent or something like that.
I appreciate any help you or anyone could give me on this.
Here's Mine
Cyberdyne digital trans temp running to tranny cooler up high. AEM wideband UEGO A/F controller with Bosch O2 sensor hooked up to Megan down-pipe. Also have scangauge which monitors everything else i need.
Hey Sumo,
Hey.. Id love to help but even this was a lil too complicated for me.
You should email Ben at AJR. Im sure he will be glad to help
