kelsodeez dyno sheets..........FINALLY!!! (T1R TURBO)
Old Aug 10, 2008 | 01:16 AM
TOOL's Avatar
Totally impressed bro!
Awesome numbers!
Old Aug 10, 2008 | 01:25 AM
kelsodeez's Avatar
UNBANABLE
Originally Posted by FELIXY69
Yep 8psi would bring to 200hp that's for sure but how long will it last??
keep it simple or do it up right
eitherway congrats
are u on the blue
emanage or the silver one ??
im on emanage ultimate (the silver one). my plan for more boost is to add an oil cooler, hook up the water sleeve on the turbo, colder spark plugs, new fuel pump. i need to make a to do list, a parts list and do more research before i start looking for a boost controller or a new spring.
Originally Posted by kylerwho
how much boost will the stock L15 take before meltdown?
i think skunk2 blew an L15 at 15psi. i forget.
Old Aug 10, 2008 | 10:56 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
You should have colder plugs now. A fuel pump will stop the lean condition that T1R is having at 8-10psi.
Im surprised that they havent noticed this....
8psi is plenty safe for the L15.
Old Aug 10, 2008 | 11:00 AM
drzenitram's Avatar
anyone else hear about no aftermarket controllers being able to change timing on the fit?
Old Aug 10, 2008 | 11:04 AM
Posts in the NUUDE
All those piggy backs can change timing. The HKS kit was using almost stock timing under boost. A little scary.
Old Aug 10, 2008 | 03:59 PM
kylerwho's Avatar
spoon fed
im curious if you get forged internals how much could it hold. wonder if this motor could be pushed to 250 doubtful but possibly 300?
Old Aug 10, 2008 | 08:01 PM
kelsodeez's Avatar
UNBANABLE
i do have colder plugs. my spoon plugs are like a step or two colder than stock. i forget. but i need to replace them soon so when i get new ones, ill get them another step colder just to be on the safe side.
Old Aug 10, 2008 | 08:03 PM
kelsodeez's Avatar
UNBANABLE
the weak point of the L15 are the thin port walls inside the head. so getting more than 200 safe horsepower is kind of unrealistic.
Old Aug 10, 2008 | 08:08 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
that kind of sucks..
well not really, 200 hp in a fit is still straight sex
Old Aug 10, 2008 | 11:49 PM
underdog's Avatar
so the cylinder head will crack under excessive power? wow go honda
Old Aug 11, 2008 | 01:56 AM
BlueCell's Avatar
Great numbers! I'd like to see how much I'd make on a dynopack, but I don't know anyone with it. Good luck on the customizing. I'm in process of doing that, but it will take time for me, low on cash. Go kelsey! Big Baller!
Old Aug 11, 2008 | 05:00 AM
  #32
i don't think honda really knew people would be TRYING to put that much power in the little L15,...
it essentially IS a little eco car
i mean, it's a bad ass eco car, but an eco car nonetheless
Old Aug 11, 2008 | 05:13 AM
  #33
kelsodeez's Avatar
UNBANABLE
no, its not that the walls of the cylinder head ports are weak, its that they are super small that getting alot of power out of them is difficult. trying to bore them out is difficult because the walls are thin and it is easy to bust through them or just make them really really brittle.
Old Aug 11, 2008 | 05:28 AM
  #34
ahh i see.
haha kelsey you're always up real late!
and every time i'm on myspace late at night i see you on my little "online friends" thing
Old Aug 11, 2008 | 05:29 AM
  #35
kelsodeez's Avatar
UNBANABLE
haha yea ima night owl. but i gotta wake up at 7 to go to work and make money to support my car habbit.
Old Aug 11, 2008 | 05:30 AM
  #36
gosh 7?!!!!
if i were you i'd be way out by now
i plan on waking up at noon ATLEAST
Old Aug 11, 2008 | 09:52 AM
  #37
eldaino's Avatar
why should they build every engine with the intent that someone will mod it?
anyway, i can't see the dyno's kelso, but since you physically typed the numbers, needless to say i'm impressed.
so you are at 6psi? does the emanage already come pretuned like that or did you have to up it to 6?
Old Aug 11, 2008 | 11:51 AM
  #38
kelsodeez's Avatar
UNBANABLE
i think the emanage comes pretuned for 4.5 psi but the wastegate spring is rated at 6psi. im not 100% sure about that.
Old Aug 11, 2008 | 12:01 PM
  #39
BlueCell's Avatar
Do you have a psi boost gauge or bar gauge?
Old Aug 11, 2008 | 12:05 PM
  #40
kelsodeez's Avatar
UNBANABLE
its a bar boost gauge but the conversion isnt hard. its like 14psi to every 1bar.
