kelsodeez dyno sheets..........FINALLY!!! (T1R TURBO)
Old Aug 11, 2008 | 07:36 PM
  #61
kelsodeez's Avatar
UNBANABLE
yea, i just use honda factory coolant. they pre-mix it with distilled water so the ratio is perfect. water wetter wont improve or decrease heat dispersion but it is mandatory to have if you are ever on the track in case of a coolant spill on the tarmac. it makes cleanup easier. never heard of it turning into gel but ive only dealt with it in motorcycles.
Old Jan 18, 2009 | 03:01 AM
  #62
kylerwho's Avatar
spoon fed
any news of the water cooling lines to your turbo kelso?
Old Jan 18, 2009 | 03:18 AM
  #63
kelsodeez's Avatar
UNBANABLE
nah, i figure that its such a small turbo and it doesnt get abused to badly so the coolant and the oil would be a little overkill. also, i am getting close to being done with my car and i am trying not to think of other things to do to it hahaha
Old Jan 18, 2009 | 03:25 AM
  #64
kylerwho's Avatar
spoon fed
do you have any heating issues since your not running an oil cooler?
Old Jan 18, 2009 | 03:27 AM
  #65
kelsodeez's Avatar
UNBANABLE
not really. my car will top out at 90C after hard driving and idling. my oil temp gauge isnt hooked up right now but i think i would like to get an oil cooler. or at least send my oil away for analysis to see what needs to be done because even with synthetic, at top temp, my oil feels really thin.
Old Jan 18, 2009 | 03:35 AM
  #66
kylerwho's Avatar
spoon fed
how about your water temps?
im getting the t1r kit in a month so im trying to figure out all the kinks now.
Old Jan 18, 2009 | 02:06 PM
  #67
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
there's no such thing.
hehe
Old Jan 18, 2009 | 02:40 PM
  #68
kylerwho's Avatar
spoon fed
there is such thing. he can be done with the fit since he is moving on to the datsun.
Old Jan 18, 2009 | 02:46 PM
  #69
ohh yeah i guess you're right.
dang.
Old Jan 18, 2009 | 02:51 PM
  #70
kylerwho's Avatar
spoon fed
or..... he could trade me his fit for mine and start the building process all over again.
Old Jan 18, 2009 | 03:23 PM
  #71
haha you would love that too much.
Old Jan 18, 2009 | 04:30 PM
  #72
explosivpotato's Avatar
My water temps stayed roughly the same, when it was warm. Of course, if I got into it, then stopped abruptly at a light, oil and coolant temps could jump to 180-195, but as soon as you move again it cools back down to 170-175 (all temps in *F).
Now that it's the dead of winter, my water temps cling to about 175 when I'm at a steady pace; I'm assuming this is because the radiator is so cold from the incoming air (been in the negative single digits lately) that the thermostat is taking a bit longer to open, and the coolant sensor is on the engine side of the coolant circuit (obviously).
Oil temps in the summer were between 180-220*F, while stock was ~175-185*F. With it being winter and all, I don't see above 175*F, no matter what. Not surprising, but since I only ever use fully synthetic (I would say a MUST when turbocharging a hi-compression motor like the L15), I'm not worried. Synthetic oil flash points are often in the range of 400-500*F. BTW I'm not running any sort of aftermarket cooler. Stock everything minus my pressure/temperature senders in a sandwich block.
Old Jan 18, 2009 | 06:42 PM
  #73
kelsodeez's Avatar
UNBANABLE
thank god i dont have to deal with such drastic weather changes like you guys up north do.
Old Jan 18, 2009 | 06:48 PM
  #74
kylerwho's Avatar
spoon fed
so what weight of oil are you guys running? brand?
Old Jan 18, 2009 | 07:00 PM
  #75
kelsodeez's Avatar
UNBANABLE
i was using 5w40 greddy oil but that stuff is too thick and it made my engine run a little sluggish.so i started using 5w30 greddy. now i am running 5w30 eneos oil but i think i am going to switch back to greddy oil because the eneos gets thin alot faster than 5w30 greddy oil did.
Old Jan 18, 2009 | 07:04 PM
  #76
kylerwho's Avatar
spoon fed
are you running a catch can too? any pics? thanks for the info.+rep
Old Jan 18, 2009 | 07:17 PM
  #77
kelsodeez's Avatar
UNBANABLE
i need to run a catch can. i just havent got around to picking one up. i really need to tho.
i think i am going to start doing this
https://www.amsoil.com/storefront/oai.aspx
porkchop
120
Jun 20, 2011 04:39 PM
keepitpg
29
May 21, 2010 08:23 AM
Illusive
357
Mar 26, 2009 01:32 PM
fitDSfield
Aug 16, 2008 12:23 AM
gn-it&rn-it
14
Apr 11, 2007 12:26 PM
