building the l15
Old Dec 30, 2013 | 03:57 PM
13fit's Avatar
Originally Posted by TPColgett
13fit what do you mean by a "real" IM?
Using consistent trap speeds and exact weight I know I'm making 110 at the wheels. That is just "bolt on's" a good exhaust and tuning.
What I mean by a real IM?
Runners that arent as long as the engine is tall damn near, and a real plenum that doesnt suffocate cylinder 1 or overdrive cylinder 4
Think B18C5 integra Type R manifold design. That manifold gave edelbrock and skunk2 absolute hell when both companies were trying to create an improved intake manifold for the Type R. Honda definitely did their homework when creating the B18C5. I belive the awesome PerformerX from edelbrock only netted an average 2or 3 horsepower over the OEM piece, though edelbrock did get more usable power under that long curve!
Old Dec 30, 2013 | 04:57 PM
TPColgett's Avatar
I cannot honestly claim to have any engineering ability when it comes to designing an IM, but I do have one of the Weapon R ones
I preemptively sent it out to be inspected and braced, but it still would need an aditional vaccum tee added before it would be a direct swap/install. Frankly it would also need porting to clean up the runners after the bracing welding seeped in
Form all the research I can do, they did appear to make gains over stock, but fitment, durability and tuning issues really made them a non selling item. Still the one actuall dyno graph I found was something nuts like 12whp
Bi$i's Golden Eagle IM has a host of other things to deal with besides just clearance as it relocates the TB to a bottom center mount.... Which is AWESOME, but really impractical for the average user. Fab is certainly required, and what little I can tell of IM design, it is really only good for a FI setup.
In a Fwd application, if your trying to go effectively around any low speed corners it is insanely difficult to make use of any more than around 225wtq or so...
So, going off DSM's ( ) thoughts and my primary application for the Fit being AutoX, I am almost begining to think that I may not need to do a rotating assembly build to get close to the right ball park on an intial FI build...
Then again, I just recently started a campaign to have Fit's classed into a class where all intake track modifications are allowed, so if that happens I will be monkeying with either the IM I have or potentialy ITB's before I start playing with turbo/SC setups...
Old Dec 30, 2013 | 06:01 PM
apexanimal's Avatar
Irtb's ftw...
Old Dec 30, 2013 | 06:22 PM
TPColgett's Avatar
Oh, LOL and apparently these are now on sale 50% off
L15 and LEA1 H beam rod set - $419.99 : Bisimoto Engineering, Where Efficiency Meets Technological Perfection
Steel H Beam Featuuring ARP bolts.... Sooooo same as K1? LOL
$385
http://www.summitracing.com/parts/ko...FRSFfgodIDkA7A
Old Jan 4, 2014 | 03:47 PM
Stevens24's Avatar
So I am wondering if I need to sleeve the block before building the bottom end. Or just blueprint everything before putting the forged internals in? Also thinking of cryo treating the crank. Any one have any thoughts? Motor has 70k original miles.
Old Jan 4, 2014 | 03:57 PM
Stevens24's Avatar
The engine will be turbo running 8-10 pounds of boost at altitude.
Old Jan 4, 2014 | 04:24 PM
TPColgett's Avatar
So 8-10 psi is actually right around the top of the "safe" zone for stock factory internals.
I know a boosted GD on stock internals that is over 180+ whp and driven daily on 9-10psi.
I have NO idea what altitude will do to the equation though.... Only time I have seen a block sleeved was when they were pushing more than 20psi, so I don't think that is needed. Honda also uses forged cranks, so that is not really a weak link.
What it really seems to come down to is budget... K1 Rods and Wiseco Pistons (standard bore and lower comp at 9:1) as per DSM would be more than enough for your build it sounds like. If you want to throw a full blue print at that it cannot hurt. Only really important things you haven't mentioned yet are supporting fuel mods, IE 310cc injectors and a fuel pump. Also I would at least run the IK-22 plugs gapped to smaller than spec.
Old Jan 4, 2014 | 04:54 PM
Stevens24's Avatar
Well it will get forged internals valves,springs a cat cam and a cleaned up head. So I am not worried about internals. Obviously as pat of that it would get better injectors and plugs. First purchase is the Hondata. Then will start acquiring the rest. Goal is to have everything by Dec. and pull the motor over winter since i won't need to drive the car.
Old Jan 4, 2014 | 04:58 PM
TPColgett's Avatar
Shoot, I would throw on a clutch at that point as well since especially with a cam and boost you will be making a significant step up in power.... I'd also delete the stupid Clutch Delay Valve which will help with hard 1-2 shifts
If you need a FlashPro there is a STEAL here in the classifieds right now!
https://www.fitfreak.net/forums/sale...-flashpro.html
Old Jan 4, 2014 | 10:04 PM
hehn's Avatar
Right now I am at 9 with 200whp and daily drive. Someday I'll try to push it to 300whp, but that'll be a while from now.
Old Jan 4, 2014 | 10:07 PM
TPColgett's Avatar
What sort of setup? Based on a kit? Additions? Assuming tuned on FP...
Old Jan 4, 2014 | 10:24 PM
  #32
hehn's Avatar
Some of the info is in the Ramey built turbo thread. My exhaust is a skunk2 catback with a Megan axel back modified to fit. No catalytic converter.
No plans for the 300whp yet. I am busy with school and trying to build an 86 crx si.
Old Jan 4, 2014 | 10:40 PM
  #33
TPColgett's Avatar
Oh duh! I thought the Ramey build was yours. Still some VERY clean work
Old Jan 5, 2014 | 12:03 AM
  #34
Stevens24's Avatar
You are on all stock internals also Hehn right? I emailed them in regards to the manifold. they have the cleanest I have seen so far. I have a laundry lis of part to acquire this year.
Old Jan 5, 2014 | 12:26 AM
  #35
TPColgett's Avatar
Email also sent LOL
Old Jan 5, 2014 | 07:03 AM
  #36
hehn's Avatar
Yeah all internals are stock for now.
Old Jan 22, 2014 | 04:33 PM
  #37
TPColgett's Avatar
So I have been getting BORED and started collecting/recording specs and data as well as playing with data (Mostly IM runner length wave calculations.)
Figure I would consolidate info in a Google Doc and post here for anyone interested:
Honda GD Fit Facts and IM/Runner Calculations
This is for me and I will tweak/play/update when I have time. If my math is wrong or you disagree, great you can do it yourself
Old Jan 22, 2014 | 04:38 PM
  #38
TPColgett's Avatar
Also, these guys appear to be a US distributor for CAT cams and are listing specs!!!
Street:Cat Cams - Honda GD L15 Street Performance Camshaft (Fit/Jazz) drop in cam
"Race": http://www.vacmotorsports.com/catalo...ts-fitjazz.htm
And it looks like CatCams has updated there page:
http://www.catcams.co.uk/acatalog/Ho..._1.5l_16v.html
Old Jan 22, 2014 | 05:15 PM
  #39
hehn's Avatar
Did anyone find an adjustable cam gear? or is that unnecessary?
Old Jan 22, 2014 | 05:35 PM
  #40
TPColgett's Avatar
I don't know about necessity, but other than DSM who had contact with an unknown company who was considering doing it, I know of no other adjustable cam gear possibilities...
To quote one of the many informative old DSM posts:
It looks like we might have room too, but getting to it would certainly be less than convenient. I wonder how much cam angle phasing we can do with the ECU to compensate for this.. the K series have something like 50* of flexibility.
Remember, we do have a cam chain, unlike the belt's on D/B series:
