T1R Intake
Old Nov 18, 2006 | 12:32 AM
  #61
marokero's Avatar
Yup, the growl is normal, and something that I enjoy hearing Here are some pics of mine installed:
I rerouted the coolant hose to the TB. It's a pain in the @$$ to do that, but it looks cleaner that way. And the mid range does feel a bit torquier, going uphill seems to take less effort. I'm still waiting to see how this has affected my gas milage, since I drove the Fit very aggressively since installing the intake. But 28mpg was an improvement over 25mpg - that is, when I drive aggressively. I used to get 28mpg on my normal drive to work, so I'm hoping to see maybe 31-32mpg.
Old Nov 18, 2006 | 12:54 AM
  #62
Wave's Avatar
Thumbs up
Awesome pics!
By the way, was that you I passed on the LIE westbound just before Huntington on one of those rainydays this week? I was flying by in my VBP Sport AT in the HOV lane!
Old Nov 20, 2006 | 03:01 AM
  #63
vicmaro's Avatar
How much is this stuff?
What's the maintenance needed?
My Honda SA told me that aftermarket products may void the warranty of the unit because some products don't have filtration of dirt. It may cause damage in the future. Is this true?
Old Nov 23, 2006 | 08:15 PM
  #64
AJ PwR Jr.'s Avatar
Former Vendor
The filter is reusable so there's bascially not much maintenance has to be done.
I didn't have any warantee issues, I have brought my car to Honda for service and they didn't say anything about it.
Old Nov 23, 2006 | 08:23 PM
  #65
leonine's Avatar
I have to say aside from the awesome performance gains with this intake i was pretty pissed off that it did not come with all necessary hardware. It only come with 1 clamp for the filter. I had to buy 2 aditional clamps from autozone. 1 to clamp the blue rubber connector to the intake and another to go to the TB. The stock clamp is does not tighten enough and the intake was very loose. I think to spend that kind of dough you should damn well get ALL necessary hardware for installation! Plus i had to clean the hell out of the inside because it was not finished and there were pieces of fiberglass that were sticking out. Once again for that kind of dough i EXPECT a better quality product.
Very happy with the performance gains but VERY disappointed with the skimping out on hardware and production!
EDIT: I would never reuse the filter. After a while the fibers get too clogged IMO and cleaning it as opposed to getting a new one makes all the difference.
Old Nov 23, 2006 | 08:24 PM
  #66
sillypuddy's Avatar
Someone that Posts too much
your car is an overstatement to begin with.. they probably didn't know where to begin :-)
-joe
Old Nov 23, 2006 | 10:46 PM
  #67
sy11580's Avatar
Ben what is the size of the filter??? I want to get a back up filter (like K&N)
Old Nov 28, 2006 | 02:05 PM
  #68
AJ PwR Jr.'s Avatar
Former Vendor
I do sell the filters alone
Old Nov 28, 2006 | 07:50 PM
  #69
sy11580's Avatar
well, I talk with you soon on the phone!!! thank you
Old Nov 28, 2006 | 08:19 PM
  #70
805FitSport's Avatar
can someone take a pic of the inside of the chamber were the filter goes, looks like a big opening.
Old Dec 5, 2006 | 02:56 PM
  #71
leonine's Avatar
The filter diameter is 4.5 inches. You can get them from Ben or K&N has replacements. Also saw this one which i like better because the end cap is open as well.
http://stores.channeladvisor.com/hip...itemid=5409537
Old Dec 6, 2006 | 12:06 AM
  #72
JERKsFIT's Avatar
nice intake
Old Dec 6, 2006 | 10:47 AM
  #73
jtanoyo1's Avatar
Dude, I just realized you are using YUASA battery, that's like made in Indonesia.... hmmmm.
Old Dec 6, 2006 | 10:54 AM
  #74
137's Avatar
137
if anything id see if you can get one of the older weapon r filters to fit on the intake, those are really good filters from my personal experience.
Old Dec 6, 2006 | 12:22 PM
  #75
FYI, an open end cap doesn't increase flow, it disrupts flow and greates turbulance.
Old Dec 6, 2006 | 12:27 PM
  #76
leonine's Avatar
while that may be true i am planning on doing a ram air with pvc pipe. the end of the pipe would fit nicely in the center cap thus forcing more air in from outside. Then their would be more flow.
Old Dec 10, 2006 | 03:16 AM
  #77
KnifeEdge_2K1's Avatar
how's that work ... open end caps have greater surface area for the filter and should theoretically have less resistance, it's not like the air streams are going to be in opposition to each other or anything
Old Dec 12, 2006 | 09:19 PM
  #78
AJ PwR Jr.'s Avatar
Former Vendor
Something like this ?
Thanks
Ben
Old Dec 12, 2006 | 09:23 PM
  #79
eNAyeM's Avatar
Ben, you are using the T1R carbon intake with that cold-air tube right? Where did you position the tube, just below the filter? Or did you use an enclosed heatshield to isolate the intake to just the cold air tube? I'm really curious about what you did, and if it helped, since the other examples I've seen on the forum are using the stock airbox
Old Dec 12, 2006 | 10:20 PM
  #80
leonine's Avatar
nice setup! What did you use for the end cap?
