2008 Honda Fit Sport 5 sp Manual Transmission issues
Old Jul 17, 2020 | 10:06 PM
donaldfit2008's Avatar
My 2008 Honda Fit Sport with 190K miles on it won't do into gear consistently. I can, however, put the car into gear once the engine is off. The clutch does not slip at all. Once I turn the car on and get it moving, the vehicle will shift normally after 15 minutes or so. When I try to put into gear or chance gears when it is acting up, the car makes a grinding sound. I live in the Arlington, VA area and also need a recommendation on a reasonable shop near me to look the car over and repair it. Thank you.
Old Jul 17, 2020 | 10:55 PM
petelite's Avatar
The clutch isn't releasing as it should. The hydraulic clutch may need to be bled (easy), but if that's not the issue then it'll need a new clutch.
Spartan_1337
Sep 6, 2018 10:53 AM
Sono
Aug 3, 2017 04:23 PM
chubbs899
Oct 22, 2014 04:37 PM
dutchdog
Oct 29, 2013 02:19 PM
sean5995
Dec 14, 2012 02:20 PM
