Audio Upgrade 2007 - 2008
Working on upgrading all of the cars audio system. Unfortunately this car is very weird as opposed to all the other Hondas i've owned. Even though there are some sweet forums with a lot of pictures it just doesn't give me enough confidence to take this on myself. Are there any videos of 07-08 installations for amps, subs, or head-units?
First go on different sites and write on paper the things you want. Then post us the list. I assume you want to add all the tech new cars have stock and more. This will keep you happy in this age of car. Get a double din deck with navi/usb/apple/android/bluetooth, then components up front, 2/3-way for back door and an 8/10" sub. Take your time then get back to this thread. We're all glad to help. 1st gens look good with updated audio. The cabin is soo small you dont need much amp to make things loud.
I'm in the same shoes. Bought a single din headunit since none of the double din actually worth spending the money on and the extra DIN give me storage room.
Still not decided on whether or not to go with component speakers or not. ( i have the base model and i'm not sure on if there is even room for the tweeters )
So adding navi, bluetooth, usb, SiriusXM, etc to the base makes nothing worth the extra cost?
Nope...
This all depending on which model Fit you have for starters.. The Sport has separate tweeters in the front doors, while the base version does not. No matter which version you have, the speakers are going to be shit and need to be replaced if you enjoy listening to clean, clear, and loud music. I was able to install 6 1/2 component speakers in the front and 5 1/4 components in the rear, just needed to cut some holes to get the tweeters mounted in the rear. With that being said, a subwoofer should be added just for a more dynamic sound. I have a 6 1/2 inch sub (JL Audio microsub w/ JL 300 watt mono amp) under my back seat so it doesn't take up any space in my trunk and I get plenty of base out of it. Hooking up a radio (single/double din) is pretty straight forward, with the correct wiring harnesses and dash kit it's pretty simple. The easiest amp to hook up for internal speakers is one of the compact units made by Alpine, Clarion, or Pioneer that fit behind the dash. They wire in to the radio's harness and save running extra wires to your trunk for an amp. They generate 50 watts per channel, and if you get good speakers that are around 50 watts RMS then you won't have any issues. Feel free to ask me any questions ;-)
Obviously stock speakers always suck i already replaced the fronts, i plan on keeping the amp w/ the sub because i plan on putting a lot of power into the sub itself. I don't think i'm going to use the amp to power the speakers just the sub, i'm just going to get a good H.U. to power the speakers. or so that's my plan does anyone have the site with the right dashboard for 08 fit sport, to change out the head unit? i was thinking crutchfield?
Crutchfield sounds pretty legitimate, i'll probably go with them. As far as money goes, not sure i guess a hundred to a few hundred whatever seems reasonable. Also, i already replaced the front speakers with lower wattage Ken Wood speakers just to make the quality a bit better, what would you suggest for the back i believe they're kickers and 6 1/2 as well?
You should be able to get something decent from crutchfield with out spending a ton of money, especially if you get the dash and wiring kits for free. As for the back doors, I tried 6 1/2 but they were too big so I would say go with 5 1/4 to be on the safe side. Kickers are good, I also like alpine, pioneer, and Rockford. I actually use Focals, they are a little more expensive but definitely cleaner. As far as radios go, stick with alone, pioneer, or clarion.. I've had really good luck with all of those ;-)
Sorry for stealing your thread but i'm in the same place and i feel like these guys are actively answering questions so i'm just going to piggy back of your thread. \
My base model GD3 fit doesn't have any tweeters holes precut (at least my dumbass can't find any on the dash or door. )
I bought the Pioneer MVHX560BT on amazon, does it come with "dash kit, wiring harness, antenna adapter" or do i have to buy that separately ?
i pay about $47 for the metra kit on ebay. It arrived with a broken bottom post and i'm currently waiting on the replacement.
Anything aftermarket (Alpine, Pioneer, Kenwood, Rockford, Polk, etc) will be an upgrade over your stock speakers. What you need to look at is the RMS, if you are only powering the speakers with your headunit then you want something in the 35-50 watt RMS range. Anything more then that you won't have the power to really push the speaker magnet. I'm running Focals in my doors which are rated at 50 watts RMS using an Alpine amp that pushes 50 watts so my music is clean and clear.
Hello there, im in the same situation BUT mine came with a totally different radio unit that ive seen all over this forums or ebay. I dont know what to do with it.
I was thinking on getting a 6-7" tablet and maybe set up a carcomputer or something but im worried about how the sound would be affected.
Wow!! Now that I've never seen.. But to be honest, that's actually not a bad setup! It looks like a generic double din dash kit with a generic Honda single din radio and storage container. Get the dash kit pulled out so you can remove the radio and it looks like you can install which ever radio you want. Leave in the storage bin for a single din radio or pull out both for a double din radio, no need to hook up a tablet ;-)
I understand some things are different between RHD/LHD, but for a completely different dash it's just silly.. I will say I'm jealous of that dash, would have made putting in my radio so much easier! Lol
