How to change the foglight's bulbs?
Old May 11, 2008 | 11:49 PM
tommyinsane's Avatar
Old May 12, 2008 | 12:09 AM
Fit of RAGE's Avatar
on the side of the foglight housings, there's a 10mm bolt with a phillips head on it. Use either a 10mm socket/wrench or a phillips screw driver to remove it. Then tip the foglight housing outs. disconnect the wires and you're good. Twist the bulb counterclockwise to unlock the bulb.
Old May 12, 2008 | 12:13 AM
TOOL's Avatar
Yupp, as easy as that!
Tyler
Old May 12, 2008 | 01:53 AM
LOL thanks
sdiesel619
Oct 18, 2010 01:21 PM
AnlDyxp_GD3
Apr 28, 2010 12:10 PM
bestfit
Feb 1, 2008 04:38 PM
Deivioncrx
Jan 8, 2007 03:48 PM
pedaler
Nov 28, 2006 11:51 AM
