Keyless entry wiring diagram?
08 SSM Base/Man
I have installed the Honda fob keyless entry and would like to have my LED footwell lighting come up when I unlock the car. Any output from the module that is triggered on "unlock" would be fine. I am using an Arduino to sense this and PWM to dim.
I dont need to bother anybody with any thing other than Keyless entry module/wire ID, everything else, Ive got covered:
This will be part of my finally getting my LEDS up and running;
ON with door open, stay ON while door OPEN, when door CLOSED after being opened, stay on for delay time, fade out.
ON with manual dash switch, fade according to trimmer.
On with Keyless Entry unlock (only), stay on for 25 seconds, go OFF. If door opens, switch to dome timing.
Any body have a wiring diagram, or hooked up anything to the KE ?
edit:
I am aware of pins 9 and 10 on the back of the gauge cluster (master lock/unlock--40 pin plug) what I am really interested in is the output from the keyless receiver module (should be a 5 pin plug)
Thanks
edit:
Thanks
07hatchfit
Feb 29, 2016 07:15 PM
eriko
Jan 22, 2010 02:19 PM
ex99125b
Jan 17, 2009 10:45 PM
