6000k HID On My Fit In Action...
Old Jul 10, 2006 | 04:12 PM
MirrorWorks's Avatar
To be honest, those look pretty dull for real HIDs. The evo link is more like how bright they should be in terms of output.
Tre
Old Jul 12, 2006 | 09:08 AM
corey415's Avatar
The reason why the Fit cutoffs look dull is because the stock Fit optics are halogen reflectors. The evo cutoff was created by a halogen projector.
While not a HID projector, a projector in general will create a more defined cutoff and more light output.
Old Jul 17, 2006 | 04:26 PM
Tomh's Avatar
Senior Member
They're also looked dull due to the fact of being a 6k kit, whereas if he would have just used a stock 4300k kit then the light output would have been greater.
Old Jul 17, 2006 | 04:37 PM
buttahball's Avatar
ill be right back...lemme go find my camera and ill show u my 6000k HID kit
Old Jul 17, 2006 | 04:57 PM
buttahball's Avatar
Lightbulb Check out MY 6000K HID kit on my fit
Old Jul 17, 2006 | 05:53 PM
Tomh's Avatar
Senior Member
Originally Posted by buttahball
Dear god i've been blinded, do you have an ypics of that up against a wall.
Here's my 4300k kit from just lower then the height of your taken, and i'm not nowhere near as blinded, and mine is alos much clearer aswell, might have to do with the lower heat range though.
Old Jul 17, 2006 | 08:52 PM
FikseRxSeven's Avatar
thats a lot of glare from that angle
Old Jul 18, 2006 | 12:58 AM
buttahball's Avatar
lol i know...sorry...lemme see if i can find another angle/shot...
Old Jul 18, 2006 | 01:01 AM
buttahball's Avatar
20 feet out...HIDs only, no fogs
Old Jul 18, 2006 | 01:12 AM
buttahball's Avatar
HIDS only NO FOGS @ night
Old Jul 18, 2006 | 01:17 AM
buttahball's Avatar
SIDE SHOT of MY HIDs
  #32
st3alth's Avatar
your HID looks kinda scary @ nite buttah.. superglare?
Old Jul 18, 2006 | 02:00 AM
  #33
so you still get the cutoff..... doesnt look as sharp as it would with the halogen, but looks like its pretty clear in the distance, (im assuming that the light cuts off right below those taillights in front of you.
what kit did you use again? and do you happen to have a picture of the HID bulb that you used?
Old Jul 18, 2006 | 02:41 AM
  #34
buttahball's Avatar
superglare...........
H&K
"Jet" HIDs
Old Jul 18, 2006 | 10:47 AM
  #35
corey415's Avatar
The wall cutoff shot that you took appears to have been taken at too close of a distance.
The result is kinda funny though, it looks like you can see two faces in the shot.
Old Jul 18, 2006 | 11:09 AM
  #36
Originally Posted by Illusive
My Fit was about 10-15 ft away from the wall when I took this pic...didn't change the position of the headlights...
seems like this kit clearly has the best cutoff line with the least glare. according to the sig. its a helios h4 kit 6000k. xbritehid and buttaball... what hid kits do you guys use?
Old Jul 22, 2006 | 10:26 PM
  #37
TomiGunz's Avatar
Frequent FitFreak Poster
I would like to know what HID kits you guys are using too...
Old Jul 27, 2006 | 10:53 AM
  #38
fusionchicken's Avatar
bump for what kit everyone with pictures is using.....i'm in the market for a kit now and i want a 4300-6000k with best cutoff and least glare...thanks
Old Nov 9, 2006 | 02:32 AM
  #39
jthai's Avatar
do you guys still have your highbeams?
Old Nov 11, 2006 | 06:33 PM
  #40
Tomh's Avatar
Senior Member
no, but i'm back to working on my HID retro, which will give a me a high beam once i'm done.
