Honda Fit - Poor Headlights according to IIHS
Old Nov 23, 2017 | 02:52 PM
sjd's Avatar
sjd
Originally Posted by woof
This Insurance report is the first comprehensive study they've done on car headlights and as such is a shot being fired across the car manufacturers - and regulators - bows to get their attention on this issue. Brighter headlights are not by themselves a solution to the problem and in fact may simply create other problems. We are probably heading for computer controlled adaptive LED technology much of which is not legal in the US presently. Changes to cars take time, particularly when it involves new technology, so the reports on headlights will probably be dismal for a long time to come.
Originally Posted by GAFIT
They seem to even rate some of our better headlights (like the VW's HID's) as Poor.
I'm king of glad. There needs to be an awakening by our DOT. They are so behind the times by not allowing technology that prevails in the rest of the world to be used here.
This was exactly my point above. Just because you have a car with HID's or LED's doesn't make them any better than halogens. North American lighting standards are way behind the rest of the world.
Old Nov 23, 2017 | 03:01 PM
Originally Posted by sjd
Stomp all you want because I know both the GTI and Golf R come with bi-xenon HID's with AFS so that's what I researched on the IIHS site and those are the headlights that they ranked poorly. I've owned cars with HID's in the past (my MX-5 has them currently) so I understand the technology and have also worked in the automotive industry for a decade.
So be careful falling off your high horse.
2017 Volkswagen GTI
As you can see the halogens of the lower trim model GTI also rate poorly. Also, if you're so concerned about how halogens suck maybe you'd consider buying your wife a different car instead of an econo-hatch while you have the expensive cars.
sjd- do yourself a favor and drive one back to back at night and you will see wat i mean. you can argue all you want but i being an owner of all 3 cars i know wat im talking about. GL to you and have a happy thanksgiving.
Old Nov 23, 2017 | 03:27 PM
sjd's Avatar
sjd
I've driven many cars over the years including the current GTI and STI so I am familiar with 2 of your 3 cars and the Golf R uses the same lights as the GTI anyway. I didn't say they were as poor as the Fit's lights, I said they are still rated poorly by the IIHS. Being an owner doesn't mean you know what you're talking about, it means you're a fanboi.
Old Nov 24, 2017 | 11:48 AM
TorontoBoy's Avatar
I, too, find the GK's lighting inadequate on cloudly or rainy nights, but ok for clear nights in the city.
Also note that as we humans age, over 50yo our eyes are less sensitive to light and therefore need more illumination to perceive the same light intensity as the young punks.
Old Nov 24, 2017 | 12:11 PM
yah, if one's driving in the city with good street light illumination it's probably acceptable.. but i live out in the burbs where some streets are in wooded areas in pitch darkness. unless i use high beams i cant see much of anything especially in the rain and would NEVER be able to see deer dat could pop out of nowhere. if i have oncoming traffic i cant use high beams and makes for an unpleasant drive.
i dont have this problem in my cars and my wife should not have to either. thinking about getting her a new NX next year when the GK hits close to 30K.
Old Nov 24, 2017 | 03:33 PM
nomenclator's Avatar
I found the Fit's headlights on both high and low beams be be poor on the staightaway, equally poor on both sides, and truly awful on curves, equally awful on both sides. I agree with the insurance co report that they don't present glare to oncoming drivers.
Old Nov 24, 2017 | 05:45 PM
Spyke's Avatar
My low beams are surprisingly very nice. I do find it odd that Honda chose to go with a flat cut-off instead of the traditional right/passenger side uptick.
The high beam pattern however is atrociously miserable. light and dark spots, beam scattered all over the place. IDK what to do that would fix this.
I have ordered some high powered LED bulbs that can be variably indexed, so I am wondering if that will help. If nothing else, my low beams will have even more power and I will just manually aim them a bit higher.
Old Nov 24, 2017 | 08:05 PM
Brain Champagne's Avatar
Those of you complaining about the headlights on the GK should've driven a GE. Those were awful.
Old Nov 25, 2017 | 10:59 AM
Spyke's Avatar
Or an e30/e36 with stock US market lights
Old Nov 25, 2017 | 02:54 PM
bach's Avatar
I had a problem with the headlights after I got the car but I raised the aim a few degrees and it's made a big difference. Also agree that it would be nice to have a bit more side illumination ... I often use the EX's fog lights for that but don't like to keep them on all the time.
Old Nov 25, 2017 | 04:12 PM
My S2000 lights are way brighter than my Fit's.
BUT they are much more focused & I find my visibility is worse with HID projectors than with the classic halogens in my 2012 Fit.
I welcome new technology, but gimme my old school lights until the new ones are better setup.
Old Nov 25, 2017 | 05:53 PM
  #32
Uncle Gary's Avatar
I have owned a GE. Maybe that’s why the GKs lights don’t seem that bad.
Old Nov 25, 2017 | 10:41 PM
  #33
I didn't find that raising the aim a little bit helped much. If I raised it any further than I did I think the high beams would be too high. My main complaint is with the side illumination. I'm glad to hear you found your fog lamps helpful because instead of replacing the headlamps with brighter lamps, and adding DRL's to the the bumber, I've been thinking instead about simply adding white fog lamps. Only problem with that is that I'd have to snake wire from the bumper to the cabin, in order to add a switch. I might have to add a relay too, depending upon how much juice the fog lamps draw and how many amps a suitable switch is rated for.
Old Nov 25, 2017 | 11:53 PM
  #34
bach's Avatar
Originally Posted by nomenclator
... I've been thinking instead about simply adding white fog lamps. So I'm glad to hear you found your fog lamps helpful.
Yeah the fogs have turned out to be maybe the best part of the EX upgrade; it was a pleasant surprise when I realized how well they illuminate beyond the corners.
Last edited by bach; Nov 25, 2017 at 11:54 PM. Reason: I can't leave a first draft to save my life ...
Old Nov 26, 2017 | 01:03 PM
  #35
WindyMan's Avatar
Yes, the fog lights are excellent to fill in the edges around the front of the car. Seems I get something like 150 degrees or so of coverage on the 2018? There's quite a bit of throw to them, too. Last night they came in handy when I was going down a dark residential street, it helped a lot with scoping the curbs for parking.
Old Nov 29, 2017 | 02:25 AM
  #36
KikeDiaz's Avatar
does any wonder whether a honda rep or marketing guy read all the complains and address it for the next models?
Old Nov 29, 2017 | 08:10 AM
  #37
GAFIT's Avatar
I think they read the complaints and also hire focus groups. The result is that every model change the vehicle gets softer and less focused toward it's original market until the car gets discontinued all together due to lack of interest.
For any given car people are going to generally say that it could use more space, be quieter, and ride better. If the marketing department is in control, the result is death to anything sporty. This is why the best cars come from engineering based companies and not marketing based.
Old Nov 29, 2017 | 08:14 AM
  #38
gotta pay for safety and people in this demographic rather they don't pay.
so there you go. unless mandated hondas not going to change cause you folks won't pay.
Old Nov 29, 2017 | 08:53 AM
  #39
sjd's Avatar
sjd
WTF are you talking about? The Fit added Honda Sensing for 2018, one of few cars in this class to offer these features.
If you’re still going on about headlights, it’s already been pointed out that the headlights offered on most cars in North America rate poorly regardless of price point.
I seriously think you’re just still here so you can brag about the more expensive cars you own to us lowly Fit owners. Keep in mind that some of us own a Fit because we want to, not because it’s all we can afford.
Old Nov 29, 2017 | 09:35 AM
  #40
cgs2000's Avatar
OK, friends, let's all settle down. We're here to discuss cars, not dreams. Our cars are a compromise between what we want and what can be produced within $$$ limits, and marketers often overrule engineers on the product.
Meanwhile let's continue to share advice and experiences to make our car better, safer, more enjoyable. Stay calm!
