led headlight/fog install
just wanted to share my latest mod on my 18 sport.did the headlights and fogs.
both with kensun led kits. 6k top and bottom headlights need to be aimed as wellhttps://cimg7.ibsrv.net/gimg/www.fit...8e4288b33c.jpg https://cimg6.ibsrv.net/gimg/www.fit...3d1c23c373.jpg https://cimg5.ibsrv.net/gimg/www.fit...0c517938fc.jpg |
Noice! Was it a toUgh install or quite a bit involved?
Originally Posted by Aussie
(Post 1393542)
i took it to my boys shop and it literally took 10 minutes. you do have to cut the dust covers in order for the led fans to breathe definitely need to align the lights afterwards.they are really bright as well lovin it thus far! |
Can you go into more detail on the exact kit? I see kits for $40 and $100 but they seem identical .. the more expensive one has anti flicker resistors already ?
The cutoff looks good but i dont see any housing on the pictures of the bulbs, did you do something with your existing headlight housings ? DRL still work ? |
Originally Posted by calafricano
(Post 1393543)
it was pretty straight foward.but you have to jack the car up on the bottom to do the fogs.
i took it to my boys shop and it literally took 10 minutes. you do have to cut the dust covers in order for the led fans to breathe definitely need to align the lights afterwards.they are really bright as well lovin it thus far! Post #2 in this thread shows what I used: https://www.fitfreak.net/forums/3rd-...amp-bulbs.html |
Originally Posted by ercdvs
(Post 1394691)
The cutoff looks good but i dont see any housing on the pictures of the bulbs, did you do something with your existing headlight housings ? DRL still work ? https://kensun.com/collections/led-c..._eti_led_chips https://kensun.com/collections/led-c...ith_cree_chips i pulled the fuse for the drl's no modifications to the headlight housings |
Originally Posted by Uncle Gary
(Post 1394748)
I used a "fanless" set of LEDs for my conversion and didn't have to alter the dust covers. They DO serve a purpose.
Post #2 in this thread shows what I used: https://www.fitfreak.net/forums/3rd-...amp-bulbs.html doing that way the blubs life span is much greater than the other that does not have any circulation trimming the dust cover to let the fans do its job is not an issue esp when the kensun bulbs are completely waterproof and the dust cover has a tight snug on the bulb so that no water can get into the housing whatsoever |
(Post 1395122)
i know those led's all headlight led bulbs need air of some sort so that the bulb can be cooled
I just install a kit from Amazon and it cost $36.00 Easy install amazing.. you just have to make sure it oriented correctly. https://cimg8.ibsrv.net/gimg/www.fit...5c03b25ae.jpeg https://cimg0.ibsrv.net/gimg/www.fit...ec85bf37e.jpeg |
Originally Posted by wmo168
(Post 1395177)
I just install a kit from Amazon and it cost $36.00 Easy install amazing.. you just have to make sure it oriented correctly. Amazon Link https://cimg8.ibsrv.net/gimg/www.fit...5c03b25ae.jpeg https://cimg0.ibsrv.net/gimg/www.fit...ec85bf37e.jpeg |
Water has entered and accumulated in the right fog light. Can someone tell me how is that possible ? Thank you
Originally Posted by Sue88
(Post 1395903)
(Post 1395911)
is the fog light inserted properly? meaning that if there is any gap between the light and the housing,it will cause water to enter.
thanks for the beamtech led recommendation. installed them, good cut off. agree, need to make sure bulb oriented correctly with silver cut off shield on the bottom.
(Post 1395964)
I have not changed the fog light. I don't know if precedent owner did it. The fog light where water accumulated is still working. The other fog light is not really visible because it looks like mist or don't know what exactly has formed on the inside glass. This one is not working.
Are the bulbs too bright?
Very nice!
(Post 1395177)
yah, the lamp hue looks good, now change the fogs too.. :nod:
https://cimg4.ibsrv.net/gimg/www.fit...ce365d0a80.jpgMy car's colour seems to be the same as this one.
Can someone tell me what yellow colour exactly is this car of? Cause mine seems to be of the same colour. I'm looking to buy a touch up spray paint but don't know the exact colour for me to be able to buy it online. |
(Post 1396665)
My car's colour seems to be the same as this one. Can someone tell me what yellow colour exactly is this car of? Cause mine seems to be of the same colour. I'm looking to buy a touch up spray paint but don't know the exact colour for me to be able to buy it online. |
