DIY: Install Sound Deadening/Damping
Old Feb 24, 2008 | 10:13 PM
  #81
raton's Avatar
Originally Posted by richard612
I didn't use anything solid over those holes either. I just applied the mat face-to-face one strip at a time until the entire hole was covered. Did that on all 4 doors.
ok...more food for thought. thanks.
Old Feb 25, 2008 | 03:00 PM
  #82
richard612's Avatar
In retrospect, something solid might be a good idea from a bass perspective as it would stiffen the speaker's "box."
On the other hand, the door is such an large enclosure for a 6.5" speaker that they are probably running pretty much "free air" from a tuning perspective, so having a passive radiator made of RAAMmat probably doesn't change things much.
Old Mar 3, 2008 | 03:01 AM
  #83
RubyQQ1211's Avatar
Interested, tag
Old Mar 4, 2008 | 08:16 PM
  #84
lilmaniac2's Avatar
My 80 ft^2 of Second Skin Damplifier Pro just arrived, I should be deadening next week.
44lbs of deadener FTW
Old Mar 10, 2008 | 02:22 AM
  #85
raton's Avatar
just finished doing left-front door. ughh! what a bear. i work really slow. its much quieter. not as much wind noise. kinda seems like im deaf in my left ear. may finish up next weekend.
heres a pic of the inside w/ raammat & ensolite is selective spots--primarily behind the speakers & some other spots. u cant see it here, but i put plastic loom on the door lock mechanism, door handl mech, & various wires (see red circles). also put more electical tape on some of the wires.:
i covered the large hole w/ some aluminum flashing from home depot. used 3 self-tapping (#6x1/2") metal flat-head screws to bolt in the flashing.
also, because the large hole was covered, i had to cut a plastic piece from the door trim. this piece normally fit into the large opening. i didnt take a pic of my door , but heres smiesters door w/ the plastic piece circled in red.
heres a pick of the final step. i used the original plastic cover to as a template for the ensolite.
only problem is i applied raammat too far to the seft---they stick out when the door panel was replaced. i just need to cut it w/ utility knife & clean it up. other than that...its done.
Old Mar 10, 2008 | 03:57 AM
  #86
its.ryu's Avatar
So what do you benefit from putting on these? If I put this on my trunk area would the noise coming from my exhaust be not as loud?
Old Mar 10, 2008 | 05:32 AM
  #87
raton's Avatar
for me, i just wanted a quieter interior environment...reduced external traffic noise...plus reduced tire, exhaust & engine noise. i can still hear stuff from the outside but its becoming less & less noticeable.
also, i understand sound deadening will enhance your sound system--making bass more responsive, mid & highs more clear & defined. (I quoted that last part from Sound Deadener Showdown) i kind of notice this w/ the just 1st door sound deadened. i really want to see what the stock sound system will sound like once all other doors are finished.
so far, i like the results. it just a lot of work though..for me anyways. like i said, im a slow worker.
Old Mar 10, 2008 | 10:47 AM
  #88
richard612's Avatar
Interesting tidbit for you guys... I managed to soundproof one side of the hatch area but not the other (I ran out of RAAMmat). I finally had a rear seat passenger last weekend and I told him that only one side had been done and to try to identify which side.
I hadn't even left the parking lot and he told me "definitely THIS side!"
Old Mar 10, 2008 | 11:30 PM
  #89
raton's Avatar
cool!! bummers, you ran out of raammat. i saw in a previous post, u went w/ 3 layers of raammat in the wheel wells? did u use ensolite too?
Old Mar 11, 2008 | 12:27 AM
  #90
richard612's Avatar
No ensolite... I just crammed-in as much fiberglass as possible into every free space I could find. The area behind the wheel-well will take a lot if you keep cramming it in there.
Old Mar 11, 2008 | 02:45 AM
  #91
raton's Avatar
is this where u r stuffing the fiberglass?
Old Mar 11, 2008 | 10:53 AM
  #92
richard612's Avatar
Yes, pretty much. I got as much in there as possible with the whole side panel removed, then I replaced the panel and did the final stuffing through the access panel in your pic. I went slow and got glass in every crevice I could reach.
Old Mar 11, 2008 | 03:03 PM
  #93
raton's Avatar
thanks! i previously stuffed carpet padding (from walmart) in that area too...it really cut down the noise. i took it out when i put the raammat & ensolite. im gonna put some back in there just for a bit more noise dampening. wont pull the panels though...just gonna stuff, stuff & stuff
Old Mar 12, 2008 | 11:28 PM
  #94
its.ryu's Avatar
What would I need to just do the truck area and how much would it cost me? I don't mind the cabin sound at high speed but I still want to lower it as much as possible. Doesn't need to reduce the sound to zero just low. Thanks.
Old Mar 13, 2008 | 02:03 AM
  #95
richard612's Avatar
RAAMmat? One 62sq ft roll would be plenty...
Old Mar 13, 2008 | 02:17 AM
  #96
its.ryu's Avatar
Can you tell me how much it would run me? Im new to this stuff. Also could you link me what I would need? Thanks.
Old Mar 13, 2008 | 03:59 AM
  #97
raton's Avatar
heres some of the links & posts that helped me out:
1. this post by applemac#fit had some quick & easy ways to reduce noise in the cargo area. [https://www.fitfreak.net/forums/fit-...ml#post190728]
as per the post, i ended up getting carpet batting & stuffing it in the wheel well & in the rear panel...it really worked!...and its not expensive. i got 2 bags of batting. i had some left over so just layed it over my spare tire.
2. the 2nd post i read was this very thread (thanks smeister). smeister also mentioned this thread by invisible21 which was helpful as well. [https://www.fitfreak.net/forums/fit-...stem-pics.html]
3. after deciding to do more deadening...i had to decide which sd material to choose. this site sold me on butyl based material. [Sound Deadener Showdown]
4. i decided to go w/ raammat. its a bit more expensive than edead, but not the most expensive. u could go w/ others if u like. up to u. i ordered 1 roll of raammat, 4 yards of ensolite, & 2 cans of adhesive. it came out to $260 (including shipping to hawaii). i did the cargo area & 1 door so far. i hope its enough for 3 more doors. i ordered my stuff from here [RAAMaudio - Quality and Value in Automotive Sound Deadening]
good luck w/ ur sound deadening.
Old Mar 13, 2008 | 02:27 PM
  #98
its.ryu's Avatar
1. this post by applemac#fit had some quick & easy ways to reduce noise in the cargo area. [https://www.fitfreak.net/forums/fit-inside/18210-sound-deadening.html#post190728]
Thanks man ! I think I'm gonna stick with carpet padding and pillow stuffing.
Old Mar 13, 2008 | 03:33 PM
  #99
its.ryu's Avatar
So I just tried to buy some pillow stuffing from Wal-Mart and they have no idea what I am talking about.
Old Mar 14, 2008 | 02:18 AM
  #100
raton's Avatar
sorry to hear that. i know what u mean. i had a tough time finding it too. i finally found it by the sewing stuff. sorry, dont think the description of the 'batting' was specific enough. heres the product info:
Company = Fair Field
Product description = Poly-Fil; Extra loft batting
dimensions = full-size 81x96 inch
misc = fire retardant
i bought 2 bags...but ended up only used 1 bag. some folks have used more...just depends how much u stuff in the rear wheel & rear panels. good luck again.
heres a picture of it from a link [Fairfield: cotton batting, polyester batting, quilt, quilts, free quilt patterns, quilting, quilting patterns, Free Quilt Patterns, quilt patterns, free quilting, baby quilts].
