Subs caushing rear view mirror to shake and tilt
Old Sep 7, 2008 | 09:01 PM
Injundon's Avatar
how old are us oldschool guys?
Old Sep 7, 2008 | 11:02 PM
artieman's Avatar
Originally Posted by radareclipse
REDLINE!!!!!! Craig Smith was the "S" in G & S Designs.
He use to be my idol. Wow, that was back in the day with OD-KD tweeters and ported midranges.
Artieman, how big is your box? What batteries did you add?
1.25cu.ft. per chamber....dual chamber with single square port...port is 13.5" long with about 35cu.in. 1" mdf.....using 4 0.5farad caps on gold bar rail with batcap400....stock battery/alterator.....all 00gauge power wire.
I started young when I was 5 years old in 88 with my father at the shop we owned called classic car stereo in scotts valley california....by the time i was 10 i was doing full customer installs and fiberglass boxes on my own
the g&s redline subs are still some of the best subs i have ever seen...
aside from the cerwin vega stroker subs which ive seen literally explode boxes....
the deck im running is from fujitsu ten....front components are boston acoustic pro's that won the ces awards two years back to back(i also have the matching imaging tweeters)....all interconnects are monster cable reference series...speaker wire is all OFC 12gauge fronts and 10gauge for subs....front amp is rockford fosgate 25th anniversary limited edition punch 150.
Old Sep 8, 2008 | 01:09 AM
radareclipse's Avatar
Some of my favorite Redline drivers:
GE206 6 1/2 midbass from hell
GE7010 Unbelievable 10 inch sub back in the day-sounds oh so good.
15 inch - crap, I can't remember the model number. Maybe ODIII-15, no that isn't it.
Injundon, to answer your question: 45
Old Sep 8, 2008 | 10:47 AM
bigtoepfer's Avatar
meh. My rearview fell off twice. The people at teh dealership are always looking at me weird when i go in and ask them to put it back on. LOL. Usually when i starts to point downward i don't bother with it until it turns sideways and starts to slap the window. then i get aggravated. I find that if u set it in a position and put hotglue in that tends to work. But because the whole area where the room and windsheild meets flexes like nuts in my fit even hot glueing it doesn't really do me much good. Just seems like the mirror is attached to a bad place for people like me
Old Sep 8, 2008 | 08:02 PM
Mattocaster71's Avatar
I don't even have SUBS and I noticed my rear view mirror shaking when at loud volumes. I fooled with the rubber gasket placement and fixed some of it.
I noticed this driving home from the dealer when I first got the car. Not so much anymore.
Old Sep 19, 2008 | 01:29 PM
drock305's Avatar
i have this problem in my teg..
my friend has an '85 cadillac broughm and his mirror fell off like 30 sexonds after he put his subs in.. lol
Old Sep 29, 2008 | 06:19 PM
Fit317's Avatar
ive had the rear view mirror problem,the not enough power problem, and the windshield being popped out of the gasket problem. Yes i said correct... windshield popped out of the seal from my system.
I had 2 Kicker L7 solo-baric 15's and 2 Audiobahn A1500HCT amps. It destroyed my Fit
Old Nov 2, 2008 | 01:02 AM
krissnkev's Avatar
wow you guys are all low key...i've replaced my windshield twice!! KICKER FTW!!
Old Nov 2, 2008 | 01:04 AM
artieman's Avatar
no just not dumb enough to turn it up with the windows up...i learned that lesson in my civic with 4 ppi 12's....poped the seal on the front and back window at the same time....
Old Nov 2, 2008 | 01:08 AM
krissnkev's Avatar
i am not dumb, just the loudest girl in the united states! 155 dbs with 4,000 watts of clamped power on the dash.
Old Nov 2, 2008 | 01:11 AM
artieman's Avatar
guess i need to go compete...hit 157.3 a weighted mic on the dash with 2 12's and one 4000watt class d amp.
Old Nov 2, 2008 | 01:15 AM
  #32
krissnkev's Avatar
oooo i guess so... ... wth is a "weighted" mic
Old Nov 2, 2008 | 01:17 AM
  #33
bigtoepfer's Avatar
I think i'm in love. LOL
Old Nov 2, 2008 | 01:22 AM
  #34
krissnkev's Avatar
sorry...i got my 3x usaci wc
Old Nov 2, 2008 | 01:25 AM
  #35
artieman's Avatar
Accepted internationally 1 kHz represents the "0 dB" reference point of A, B, C Weighting and other filters utilized in acoustic measurement.
A Type 1 "A" weighted curve has a tolerance of +/- 1.0 dB.
basicly represents how the microphone is calibrated. most db drag microphones are cheap and not very accurate (more like +/- 1.7).
just showing the reading i got was true and accurate.
Old Nov 2, 2008 | 01:31 AM
  #36
krissnkev's Avatar
whats the name of it? term lab? b&k? audiocontrol? linearX?
Old Nov 2, 2008 | 01:33 AM
  #37
artieman's Avatar
www.acopacific.com makes the microphone used
Old Nov 2, 2008 | 01:37 AM
  #38
krissnkev's Avatar
ohhh....sweet i guess if that makes you better...
Old Nov 2, 2008 | 01:41 AM
  #39
artieman's Avatar
just cause you hold the record doesnt mean there isnt louder out there
just means they dont bother to compete...and my system is designed for sq not spl...it just happens to hit that high on the db meter....the guy who did the readings sets up thx theater systems for major companies around the world and works in the building across from me....thought it would be fun to see what it would do on the db...kinda a waste of his 50,000 dallor testing system for full freq scale readout with db, distortion, and harmonics
Old Nov 5, 2008 | 03:09 PM
  #40
ZiaMan's Avatar
i ended up just super-gluing my miror. I'm always sitting in the same position, so i dont really need to move it anyways
wootang00
Sep 25, 2009 12:37 PM
Reboot7
Sep 10, 2009 11:10 PM
konradh
Apr 8, 2008 09:39 AM
karoberts
Jan 15, 2008 10:26 AM
htewam
Jun 11, 2007 10:06 AM
