Audio upgrades....
Cassette Player
I'm not high tech and this question will prove it. The Fit Sport has a hookup for MP3 players. I have a lot of cassette tapes with favorite music on them and like to listen to books on tape. Will the MP3 connection also work with tape players, or do I need a different type adapter?
any outsource will work. You simply need to connect your tape player with the headset jack to the aux jack in the car. You may need to play with the volume on the cassette player. You'll probably need a male to male 3.5mm cable.
MP3/Cassette
Thanks! That's what the on-line ads seemed to be saying -- MP3 or cassette could be attached. I wasn't sure if an additional adapter was necessary. At least while I'm waiting for the car to show up, I can get a cable -- and clean out the garage!
Originally Posted by shipwrek
nice links. I was wondering what I should do to get real speakers to fit into the odd panel holes from the old speakers and the custom cut mdo would work perfectly....nice.
goodluck with that.
If stock doesn't have RCA outs like almost all stocks then you'd need a speaker wire to RCA convertor or an amp that supports speaker wire (high level inputs). I know the head unit we get in Australia certainly doesn't have RCA support.
The speaker holes in all 4 doors are 6" and surrounded on all sides by metal. Unless you'd like to start cutting metal with an angle grider your restricted to 6" and 6.5" speakers in the factory holes. If your running a sub you wouldn't want 6x9s anyway.
TequilaSqueela
Jun 18, 2015 06:01 PM
GotFitB13
Jan 1, 2015 11:44 PM
Rinzler
May 22, 2013 01:48 AM
FirefighterErik
Feb 20, 2009 09:09 PM
