My first fiberglass sub enclosure
Old Apr 26, 2010 | 06:21 AM
  #41
airhart's Avatar
So did you ever finish this? How do they sound?
Old Apr 26, 2010 | 06:28 AM
  #42
supafly50's Avatar
lol, yeh i did finish them. they sound great! not sure if they're any better than the previous box i had, but they definately use much less of the cargo space the only issues i have are getting access to the spare tire underneath (i have to move the subs to the centre and lift them up with the spare tire cover) and since i haven't put grills on them, things can touch them. haven't had any problems with things touching them yet, but i just need to be careful.
Old Apr 26, 2010 | 07:16 AM
  #43
airhart's Avatar
Nice. I was worried about having enough air to move with 10s or 12s and was considering a similar set up with a pair of 8s.
Having done it, would you do it the same or go to 8s?
And can you post pics of the finished product?
Old Apr 26, 2010 | 10:46 PM
  #44
supafly50's Avatar
To be honest, I'm very happy with my setup I've got a pair of 10's.. I think if I did it again, I would think about maybe using a couple of 12's (or even a good 15!! ) for deeper bass. But I find that the 10's are plenty for this car I don't think I would go down to 8's because I've still got plenty of space with the 10's and I don't think they would be quite bassy enough for me.. plus I've installed a set of component speakers in the front doors which come with 6's so I find they all compliment each other well: 10's for bass, 6's for mids, tweeters for highs
Oh yeh, here are some pics I took this morning.. (the white thing between the strut bar and the amp on the right is to stop them vibrating against each other ). I made the cargo cover to stop the sun baking my amps when I'm parked outside. It's a bit crappy at the moment, but it works. When I get some time I'll sort out both issues..
Old Apr 27, 2010 | 10:32 AM
  #45
airhart's Avatar
it looks really good.
i keep vacillating between a setup like yours and a single rear-firing 12" behind the smaller rear seat. just make it removable for spare tire access.
i dunno!
Old Apr 27, 2010 | 11:15 AM
  #46
Fit4Spl's Avatar
Looks like you did well, however your bass output you referred to (Deep Bass) is not bassed on sub size but rather more on enclosure. Sure with a little larger sub you might get MORE bass but not deeper. In smaller applications like what you have here its more of a filler bass and not a deep hitting bass. You would have to give up a bit more room for larger sealed enclosures or go to a ported enclosure.
You could however try putting a little acoustic fiberfill in your current enclosures, this serves to give the illusion of a larger enclosure to the sub and may give you a little more output that you like. You can pick up fiberfill from a craft store for a couple of bucks so its not a huge investment to try out.
Good luck!
Old Apr 27, 2010 | 11:47 AM
  #47
supafly50's Avatar
fit4spl, thanks for clearing that up, i wasn't sure if what i said was correct so thanks for correcting me! as for the volume of the enclosure, I made them to the size specified by the manufacturer (as best as i could) and i also added a layer of that fiberfill stuff inside the enclosure, and helped a little from what i could tell
airhart, not sure if i can help with ur decision, but personally i found my subs were too much before i upgraded my stereo and component speakers... but since then they sound just right
handymus
Jan 16, 2010 10:16 PM
chinkyy
Hawaii Community
19
May 16, 2009 10:57 PM
TWGE08
Apr 29, 2009 10:19 PM
mosquedaj
Mar 26, 2008 04:57 PM
07hatched
May 28, 2007 08:25 PM
