07 Fit With No Audio
Old May 13, 2011 | 01:38 PM
chadew's Avatar
I have an 07 Fit Sport Auto and the audio quit working with the original stereo. I just figured it was the stereo because it already had a broken display. So I decided to replace the HU with the JVC NT3HDT. I hooked it up and still no audio. Is there a fuse that runs an amp or something? What other reason would I have no sound?
Old May 13, 2011 | 02:05 PM
Jamy's Avatar
Check the fuse box for a blow fuse. I know on the GE the radio fuse is off by itself in the bottom right corner. Not sure how the GD is. I'd check for that fuse though. A buddy of mine had his blow for absolutely no reason at all, took us almost a week to figure out that is was a fuse and not something more serious like we originally thought.
Hope this helps.
Old May 13, 2011 | 04:22 PM
chadew's Avatar
Thank for the suggestion. I checked the fuse and it looks fine. I did manage to get it working. I think it was a combination of things. There was a setting in the HU that needed to be changed and one of the aftermarket speakers was hooked up wrong. I think the bad wiring was causing the two different HU to go into a safe mode with no output. Thanks again for the help.
LarryS
Jun 24, 2016 03:29 PM
trashercan
Aug 28, 2015 02:13 AM
SilverEX15
Jul 30, 2015 03:30 PM
oneder101
Jun 15, 2015 05:03 AM
ratedz
Jan 6, 2009 08:54 AM
