Springs that Dont Rub w/Backseat Passengers
Old Apr 30, 2007 | 12:26 PM
abcsr2ez4me's Avatar
I've been looking for some answers on the first page of the suspension section and everyone seems to avoid the question on if their new drop will rub or not if people are sitting in the back.
Which springs add a nice drop but I can still ride with 4 of my friends without rubbing?
Old Apr 30, 2007 | 01:33 PM
Mugen_Dom's Avatar
You also have to take into consideration what wheel and tire combination you have / will be using.
Old Apr 30, 2007 | 01:39 PM
Lets just assume the same diameter as the stock wheel. Meaning around 195/55/15, 205/50/15, 205/40/16, 205/45/16. Yes I understand that some are slightly bigger or smaller than the stock 195/55/15. But when in doubt, assume stock.
Old Apr 30, 2007 | 02:22 PM
mwr's Avatar
mwr
Okay, assuming stock then I suspect any springs and any drop would work without rubbing. In all likelihood Honda spec'ed the standard tires/wheels to travel through the entire suspension arc without hitting anything except the bump stops.
Old Apr 30, 2007 | 04:17 PM
carlosalicea's Avatar
I have progress springs and they don't rub ...
I have konig heliums 15x6.5 40 offset with 205-50-15 falkens and don't rub. It does rub when I put the Toyo RA1 but it is due to my offset because they used to rub with the stock sprins
I am talking about the back...... no problem what so ever in the front.
Old Apr 30, 2007 | 06:35 PM
aznguyen316's Avatar
+1
stock wheels then no rubbing should occur in rear w/ any springs i'd say
Old Apr 30, 2007 | 07:19 PM
iheartmyGD3's Avatar
I'm on 15x6.5 40 offset slipstreams on 195 stocks w/ tanabe df210's and at full passenger load I dont rub at all.
TPColgett
Mar 14, 2011 12:38 AM
Hootie
Oct 4, 2009 08:45 PM
betahack
May 7, 2008 03:33 PM
rabbitron
Apr 23, 2008 12:52 AM
hiphapa
Jan 23, 2008 10:44 PM
