alignment and camber troubles
Old Dec 26, 2007 | 11:18 PM
HEMI-Fit's Avatar
Originally Posted by Skimmer
OK, I looked at the manual. Each factory crash bolt gives you 4/10 of a degree of adjusting range. There are two per strut, so if you use both, it looks like the max additional negative camber you can get is 8/10 of a degree per side. Not great, but better than nothing.
Thanks, Skimmer, that's good to know - not just that I was in the ballpark result-wise, but also that you need TWO SETS of the crash bolts to max out the -camber. It begs the question(s): what are the PN's of the OEM crash bolts and what do they cost, individually or as a set of 4. Not sure why anyone would bother with only two...
Makes me think that it's probably less trouble to get the Ingalls 0-2* bolt set, set them to about -0.8*, and worry about swapping them out with the OEM bolts when it looks like I'll be chasing a trophy in Topeka...
Old Dec 27, 2007 | 01:42 PM
Skimmer's Avatar
Hehe. Luckily I anticipated your question and made a note of the crash bolt part number: 90188-SCC-A00.
But I'm not sure if that's for one bolt or a pair.
Old Dec 27, 2007 | 04:04 PM
HEMI-Fit's Avatar
Nice! That jives with what I just found in this stickied thread in the suspension and brakes section. Not quite done reading through all 11 pages yet...
Here's what I found there:
p/n 90188-SCC-A00
BOLT, FLANGE (14X57.3) (SERVICE) NO COLOR 3.57 2.68
I'm GUESSING that the last two numbers are MSRP and dealer cost for one bolt, so you'd need a total of 4 to max out. That comes in cheaper than the Ingalls parts, but doubles the effort to install.
Old Jan 7, 2008 | 11:33 AM
is it just me or does the Fit loose alignment settings pretty easily from
hitting bumps and pot holes? i hit a fairly big but not damaging pot hole
the other day and i think my front toe setting is already off a little bit.
my other cars would've been fine with that level of hit.
knm345
Apr 12, 2013 01:45 AM
J-GD3
Feb 26, 2012 08:01 PM
KeithDigital
Feb 1, 2012 11:42 AM
CrystalFiveMT
Feb 5, 2009 07:59 AM
c_mack9
23
May 8, 2008 12:01 AM
