i just ordered skunk 2 springs!?!?
i stand corrected.
Note: Skunk2 Lowering Springs lower the Honda Fit approximately 1.5” front and 1” rear. Includes two front and two rear lowering springs. Skunk2 Lowering Springs are the very finest quality for the best price.
* SUPERIOR HANDLING
* AGGRESSIVE STANCE
* EXTRA SMOOTH RIDE
Spring Rates
Front: 175 lbs./in. - 3.1kg/mm
Rear: 350 lbs./in. - 6.2kg/mm
* SUPERIOR HANDLING
* AGGRESSIVE STANCE
* EXTRA SMOOTH RIDE
Spring Rates
i'm loving my skunk2 springs, gives a great looking drop and allows you to corner alot better
i was short on time when i installed mine so i had my fronts in for about a week then installed my rears so its somewhat tilted but i just added weights in the back and now its all good
heres the intruction guide i used
How To: Install Skunk2 Lowering Springs for Honda Fit
but others said to just use these as a general guide
well, according to the spring rates, despite the subtle drop, its a lot stiffer than stock, and there is a big difference between the ratios for the front and rear. higher rate for the back = stiffer ride.
but hopefully it won't be that stiff, just comparing the numbers to other springrates.
I have 17x7 w/ 205 tires and they rub in the front. I think you could get rid of the rubbing by removing the tabs holding the fender liner and tucking it behind the fender. i noticed that when the tabs came off my fender liner on the passenger that there was less rubbing on the passenger side. was kinda funny cause i was checking the fender liner and took a look at the tab...i touched it and the tab fell into my hands lol...
I would def recommend getting a wheel alignment right after the springs are installed. I set up a alignment appointment a couple days before i installed my skunk2's so when i installed them i went right over a couple minutes later and had it taken care of. Its the best way to go. I love my skunk2's. They are stiff and the stance is great.
My fit looks slammed from the front. Ride is awesome and I love them
