Spring compression question
Its not an air tool, it just holds the spring so it doesnt smack you in the face. Most discount auto parts stores will rent the tool to you, i recomend it, your face will thank you.
Its possible that some applications would need a impact to use the compressor, but not for the Fit a ratchet will work fine.
You will have no problems with just using a ratchet and crankin the nut off. the spring has hardly no compression so it will be fine. I used my air gun only on the linkages and all the suspension stuff on the car and not for putting the strut together or pulling it apart.
BankWalker
15
Oct 10, 2010 01:02 PM
