Recommended spring compressor
Old Mar 11, 2010 | 01:02 PM
BankWalker's Avatar
Has anyone used a spring compressor to install their own springs or do you feel it's easier to take them to the shop?
What spring compressor would you recommend? I'm trying to install my Progress springs and rear swaybar.
Thanks
Charles
Old Mar 11, 2010 | 02:59 PM
k20a298ek's Avatar
you don't need one for the fit. it is a light car, the spring rates are fairly low just put your foot on the spring and release the top nut the spring will hardely move. for big v8's its a different story.
Old Mar 11, 2010 | 03:31 PM
xm8's Avatar
xm8
What if your foot slips, then the spring hits your nuts. Just buy or rent the right tool. Don't be stupid.
Old Mar 11, 2010 | 03:38 PM
krakhed's Avatar
i believe there's a DIY somewhere on here with pics up and they didn't need to use the tool for the springs.
to each their own. if i was forum savvy i'd throw the link up, but he covered the uninstall, the cutting/editing of the plastic part, and some tips.....
it was a good diy......
Old Mar 11, 2010 | 03:39 PM
BankWalker's Avatar
So I could probably rent one at Auto Zone.
Charlesd
Old Mar 11, 2010 | 04:06 PM
alvarospatchez's Avatar
yeah you dont need one for Fit's but if you insist AZ will rent you one.
Old Mar 11, 2010 | 04:25 PM
Ms. Sheila :]'s Avatar
Just rent one out at AutoZone or something for safety purposes :/
But.. I have seen people just wrap the thing in a giant RUG and pop it open like that! Not that I recommend it LOL x]
Old Mar 11, 2010 | 04:40 PM
dela's Avatar
+1 on the autozone one... its basically free... just have to make a deposit
Old Mar 11, 2010 | 06:04 PM
k20a298ek's Avatar
you dont need one.
Old Mar 12, 2010 | 01:24 AM
xm8's Avatar
xm8
Better to be safe than sorry. Better to have a good heath plan if you want to wing it.
Old Mar 20, 2010 | 05:17 PM
danger69's Avatar
I thought I didn't need one, but since I am the type to switch suspension springs it was worth getting a spring compressor. I just bought the ones from kragen that clamp down the spring coil. You will need it if your putting back your stock springs on the stock shocks. Plus its a good tool to have just in case for future use.
Old May 10, 2010 | 10:50 AM
BankWalker's Avatar
Any particular bran?
Thanks for the help.
Charles
Originally Posted by Isley
The External Coil Spring Compressor works where an internal-type compressor won't. Unlike conventional compressors, the 3 shafts fit on the outside of the spring, so you can remove and install springs on virtually any vehicle. Makes installation and removal of front coil springs much easier. Uses your 15/16" socket.
Old May 27, 2010 | 01:51 PM
danger69's Avatar
All of them are pretty much the same design.
Old Oct 8, 2010 | 04:05 PM
ramjet's Avatar
The post is from tofuman! NHBP bro. Actually, the only real biatch, is when the axel falls out. Oops. But tje spring is not under tension like a ford or others. Just use your front door mat you pansies.j/k
Old Oct 9, 2010 | 01:29 PM
Bthasht's Avatar
Axel Needs to be your biggest worry. Read the sticky diy in the fit trix section. I layed my front shock/spring assembly flat on garage floor, stood one foot on spring, bent over, and took off nut. Didn't move two inches.
Back Needs no compressor, just step down on brake drum, spring comes right out.
Rent it from the zone if u want.
Also there is sticky diy on rsb
Old Oct 10, 2010 | 01:02 PM
infamousAXEL's Avatar
Originally Posted by k20a298ek
you dont need one.
THIS
10char
pig_pit
Apr 6, 2012 03:41 AM
DSC
Hawaii Community
Aug 20, 2010 10:58 AM
kona_fit
Jul 23, 2010 03:18 AM
kancerr
Mid-Atlantic Community
Sep 18, 2008 12:04 AM
diedwater
Mar 28, 2008 01:43 AM
