T1R Front Sway Bar
Old Apr 21, 2008 | 05:00 PM
radareclipse's Avatar
Thanks. Alcantara suede. Once I saw it, I said I gotta have it. And the Fit's interior material was ooof!
Old Apr 22, 2008 | 01:35 PM
Mr08FiT's Avatar
ooof?
Yeah, that suede looks amazing! Dare I ask what you mean by ooof?
Well back to the subject at hand. The front sway came in today so I'll be installing it after work assuming the rain holds off long enough. I'll hopefully be posting pics of the sway and my car tomorrow or the next day, thanks again for all the comments.
Old Apr 22, 2008 | 10:08 PM
Big bucks. Material cost and labor cost wise. I call that Ooof!
Old Apr 23, 2008 | 09:10 AM
Mr08FiT's Avatar
Install Issues!
Ok so here's the deal... the sway came in on Tues. So after work I started the install, the factory sway was completely unbolted. Then the unforseen happened, apparently the subframe has to be loose enough, not removed, loose enough to remove the factory sway from the stock location. So I bust out the compressor, and of course my compressor is on the fritz. Needless to say I did not complete the install and had to bolt up the factory sway bar.
My question to the thread: A) For those that have a front sway bar, did you install it yourself? B) Is this the same method you had to use to install your sway bar? C) Did anyone pay their local shop to install the T1R, Aftermarket, Etc. sway bar and how much did it cost you?
Thanks in advance for any input, or guidance.
Scott
Old Apr 23, 2008 | 09:22 AM
ldweng's Avatar
Scott
Check out the Battleendless Front Sway Bar Installed Thread on page 3. You need replacement bolts for the subassembly.
Old May 2, 2008 | 08:07 AM
Mr08FiT's Avatar
Well I had the sway bar installed for me just the other week. Cost me about $200, with an alignment. And I could not be happier, all thats left is wheels/tires, or just tires. Definately "Bang for Buck" best part that I've put on the car.
Old May 3, 2008 | 11:17 AM
jsensk's Avatar
Are you running a rear sway of any kind? I have Progress rear sway and am looking at T1R front with T1R lower arm brace.
Old May 3, 2008 | 11:59 AM
SD_MR_FIT's Avatar
Originally Posted by m1kel
how's ur ride on the tein s-tech's? i have them too and my ride is SUPER bouncy
mine isnt bouncy. its actually pretty stiff.
Old May 5, 2008 | 02:24 PM
Mr08FiT's Avatar
Bars, Bars, and more Bars
No I don't have a rear sway, no front lower bar, just the front sway, front and rear strut bars, and Tein S-Techs. I'm looking into new tires soon, and I absolulety love the front sway bar. I tried putting my friends 205/55/16 black slipstreams on and they look amazing, but the front passenger side rubs the underlining of the fender. Which is weird because, on the stock wheels the driver side is lower than the passenger, but with the wheels on the driver side is fine and the passenger side rubs.... odd right. Anyways I love the sway bar, lover the springs, and can't wait to get wheels and tires of my own.
P.S.~ I'll be posting pics A.S.A.P. as soon as figure out how, asta-la-byebye.
Old May 5, 2008 | 02:27 PM
George02's Avatar
yea but you also have them cut, it makes a little difference?
Old May 11, 2008 | 12:00 PM
Illusive's Avatar
Got the T1R Front Sway Bar installed last night...wow...what a difference it makes!!!
HB1320
27
Sep 12, 2014 02:43 PM
jmsplitfyre
Jun 25, 2013 10:58 PM
j's_fit
Jan 22, 2011 05:22 PM
die_lawn
20
Jan 5, 2010 11:29 PM
saiko
53
Mar 23, 2008 01:25 AM
