J's roll center adjusters
Old Mar 11, 2009 | 02:23 PM
redrumm's Avatar
just wanted to know how many of you are running these and if it made a significant difference.
i did a search but nothing good came up. just AJR selling them.
Old Mar 11, 2009 | 05:04 PM
FITGD3's Avatar
it adjusts the front arm levels since the car lowered. reduce understeers a lot IMO.
its very pricy as well.
Old Mar 11, 2009 | 05:27 PM
kelsodeez's Avatar
UNBANABLE
they are a pain in the ass to install, and they are expensive but it makes your car feel more like it was supposed to be lowered from the factory. the drawbacks of them are, if you get a flat in the front, you cant use the spare tire. you will ruin your spare tire and the ball joints if you put the spare on. they are a PAIN IN THE ASS to install, and i mean shitty. i had one set but the anodized ring came loose and binded the ball joint in my control arm. i had to buy a new control arm and new roll center adjusters. just when you put them in, put some of the strongest loctite around the ribs that contact with the control arm and you will be good. ive never had problems with my sway bar end links being too short or too long because of them too. its a good investment but have a pro put them in and check them after a couple 100 miles to make sure they are sitting okay.
Old Mar 11, 2009 | 06:38 PM
redrumm's Avatar
damn already sounds like a pain. id like to reduce the bumpsteer
you install them with a press correct?
Old Mar 11, 2009 | 06:48 PM
kelsodeez's Avatar
UNBANABLE
yea but its almost worth it just to buy the control arm with the ball joint already in it. like this.
thats what i would do if i had to buy a third set. the control arm from honda isnt the strongest of metal and if you dont use the proper press fitting, it WILL bend the shit out of your control arm.
Old Mar 11, 2009 | 06:57 PM
redrumm's Avatar
i saw that on N1 concepts.
does that even fit our car?
Old Mar 11, 2009 | 08:47 PM
kelsodeez's Avatar
UNBANABLE
it should. i dont think the differences between the suspension of the jdm vs usdm fit is that drastically different. i think the main difference is the lower perch and thats it. i could be wrong but i doubt im wrong.
Old Mar 11, 2009 | 08:50 PM
junktea1's Avatar
I sell the RCAs from J's. Just send me a pm.
Old Mar 11, 2009 | 09:02 PM
redrumm's Avatar
well seeing its a BIA to get in, i wonder if it will fit with the control arm.
Old Mar 11, 2009 | 09:03 PM
redrumm's Avatar
what else do you sell?
MTLian
Jun 4, 2021 01:16 AM
Desmond Lamar MacRae
Mar 29, 2016 01:54 PM
da9r00d
Apr 2, 2009 02:33 PM
pokems23
May 30, 2008 11:52 AM
plastidip
Sep 12, 2007 05:45 PM
