Bumpstop - S-Tech Tein
Old May 7, 2009 | 01:32 PM
jhoprodie5's Avatar
Do we still need to cut the bump stops when installing the tein s-techs? I read through it manuals and it says there is no need for GD3 to cut it.
Seems to be odd though.
Old May 8, 2009 | 05:33 PM
it's recommended that you do. front and back...about 20-22mm.
Old May 8, 2009 | 10:18 PM
nxtfit_08's Avatar
cut 2 off and 1 coil of the back and it will sit perfect! and yes you nee to cut the bump stops
Old May 11, 2009 | 03:09 PM
jhoprodie5's Avatar
Thanks! I did cut an inch in the front bump stop and it made a difference. The ride is better now (not that harsh). Where is the bumpstop for the rear located?
Old May 11, 2009 | 03:51 PM
sounds good.
the rear ones are on the damper(shock) shaft.
Old May 11, 2009 | 04:00 PM
jhoprodie5's Avatar
sounds good.
Cool! Thanks!
mo-FUK
Oct 13, 2012 06:21 PM
LaoSiFu
Dec 14, 2010 06:27 PM
abscooter
Dec 11, 2008 12:29 AM
Sam Misled
Nov 1, 2008 10:50 PM
FitnessJay
Mar 7, 2008 01:16 AM
