HELP! Did I just Ruin my Ride?
The end links that came from Sk2 did have a certain amount of adjustment available at either end. When I had it aligned they stated the rears had a neg 3 camber, but could not be adjusted w/o shims/camber bolts. Is it worth the trouble?
I am missing the whole point here. Why are you changing the suspension Marco? You do not want to lower the car, your roads are so bad I doubt if you need the suspension for handling. So to me it looks like you are spending a ton of money and have ended up with a poor riding car which looks weird with the rake.
It seems like the installer has screwed up something or you have bought some aftermarket stuff that just don't FIT. I would package it all up and go back to stock and maybe buy a few LEDS instead.
bill
bill
I'd love the same amount of camber on the front, but the SPC bolts aren't completely plug and play - I'm gonna need to grind down some areas of the control arm and suspension before I can install them.
I wanted to respond to you earlier but didn't have time with work to devote to a proper post.
I feel your pain and I don't think its any short comings of your installer.
First off, I've gone through exactly what you have. I have another car thats been a pure suspension built car. many many thousands of dollars have gone into it getting custom bits made up and so forth (for something that does not have much in the way of aftermarket), everything was fine and dandy until me and a few others convinced D2 to design some integrated coil-overs for our car Of course being who I am I went with an insane spring rate (11k front, 9k rear. IIRC 4x the stock). AND SAME EXACT THING AS YOU... its like a roller coaster ride, fun as hell and quite scary but after a few minutes you just want to get out. Its all over the god damn road, I'm pretty sure there is an indention on the ceiling metal from my head. I literally threw up on my drive home after installing them.
let me tell you what continuing to ride your car like this is going to turn into... your going to start breaking stuff... sway bar mounts, end links, tie rods. I've even snapped a tire off the car just cruising on normal roads. you'll quickly find all sorts of new weak points and you start getting in the habit of replacing certain parts with every oil change.
I recommend you sell them off and take a small step backwards.
If not heres what you can do in the mean time to mitigate the issues. get 4 point harnesses, it'll keep you out of the roof. put your seat in a proper upright driving position, it does wonders on mitigating the harshness. REMOVE THE SWAY BAR ENDLINKS, when the springs get that stiff the sway bar is completely pointless and you'll gain a bit of roadway stability at speed. If you do choose to keep the sway bar end links, KEEP MORE THAN ONE SPARE SET ON HAND. You will be snapping those like butter, especially at the angle they are being mounted at. Also note that if they snap, there is a chance they will somehow get caught up in the rim and do some pretty nasty damage. Lower your rear so you don't have it raked, you really mess with the suspension geometry and it can have some really funky effects on the road.
My buddy has slowly worked his identical car up to the same suspension build I have and it behaves exactly how my car does not.... difference being is he is quite competitive in SCCA and has 5 years of racing it every weekend. Years of tweaking the setup have made all the difference. You can't get that result taking your car to any shop, they can't help you achieve that. It takes alot of time and experience and road time to properly dial in the car.
Theres a reason these things come with big labels on them that say for off-road use only.
Tofuman
May 7, 2011 08:39 PM
j's_fit
Jan 22, 2011 05:22 PM
nugey1001
Jul 22, 2010 03:39 AM
skunk2tony
Dec 2, 2009 10:58 PM
jsensk
138
Mar 11, 2009 11:33 PM
