Help please!
Old Dec 20, 2009 | 02:19 AM
xonexlifex's Avatar
Help please!
Ok heres my problem. I just got a set of new low offset wheels +35 to b exact. And i got a set of 205 wide tires. And the the back rubs pretty bad on big bumps but i cant get a full car anymore. I rolled the fenders and cut a lot of fender inside plastic. It still rubs. Im not going to get new springs but i need it to not rub so i was wondering what else i culd try. My uncle said i can get rubber pieces that go in the springs to make it compress as much. And i wondering if any has tried this and think it might work. Also ive seen these nascar rubber pieces that go underneath the spring to raise the spring up. Please i need help fast. Please!
Old Dec 20, 2009 | 03:17 PM
spoonek4's Avatar
I THINK Ben @ A&J told me there are these rubber pieces that sits underneath the springs llllllllllllllong time ago too? Can't remember exactly. I had rubbing issue long time ago when I had my Eibach pro-kit springs with 205 tires. Ever since I swapped out the rear Eibach back to T1R ver1 springs, not much issue unless I'm quite loaded in the back seat/trunk with my 14x6.5" +30mm offset with 185/60R14 snow tires.
U DO need stiffer rear springs with less coils or linear design sooner or later. Unless u wanna invest $ on new tires or rear camber shims.
Old Dec 20, 2009 | 04:30 PM
xonexlifex's Avatar
ya eventually but for now i need a quick fix, i found these and i think they might do the trick
the spring wont go down as far so therefore the car wont bottom out so low, great idea i just gota wait til monday to see if the local race car shop has em before i order some online
xonexlifex
13
Mar 6, 2011 04:16 PM
j1nNju1c3
Aug 13, 2010 10:04 PM
EggHead
Aug 1, 2009 01:30 AM
PHATFLIP
Jun 18, 2008 08:45 PM
