Buddy Club N+ coliover installed pics
Old May 23, 2010 | 11:06 AM
hkjazz's Avatar
Originally Posted by MPFit07
your Fit looks really nice man. Can I ask where you buy your Buddy Club?
I bought my buddyclub coilover in wirednj. But i think you can get it anywhere from the suppliers that carry them. But i heard that they only made 10 sets of coil overs for now to see the market reaction.
Old May 23, 2010 | 11:16 AM
hkjazz's Avatar
Originally Posted by FitDEEZ
congrats man , aren't they awesome!!
thanks eddie. Is great. Congrats to u too buddy.
Old May 23, 2010 | 12:19 PM
im the fit's Avatar
How much lower can you go in the rear? On this pic it looks like you can lower another 2.5 inch.
http://img168.imageshack.us/img168/6121/05162010090.jpg
Old May 23, 2010 | 12:41 PM
FitDEEZ's Avatar
They go pretty low.. check out my fit its all the way down in the rear and I can go down lower if I wanted in the front
Old May 24, 2010 | 08:15 PM
BBFat69's Avatar
I want that too
Old Jun 22, 2010 | 06:06 AM
kummaz's Avatar
Sorry to kind of hi-jack this thread
I noticed that my N+ are different to yours (Aus spec jazz/JDM) and the part that is circled in the displayed pic is completely adjustable on the thread. Not being clued up in all things suspension related, what exactly does that connect to?
I was all set to install it and then I saw that and wondered wtf it was and why I hadn't seen that on any any pics of the N+. I don't know if it comes down to us having 2 different models in terms of USDM and JDM or if its something else that I have?
Let me know if you want a pic of mine to get an idea of what I'm talking about.
I stole your pic and edited it
Old Jun 25, 2010 | 03:59 AM
feared's Avatar
thats the sway bar endlink
Old Jun 25, 2010 | 04:02 AM
feared's Avatar
Originally Posted by spoonek4
So u adjust the ride height on the rear shock body on cusco coilovers? Or both the spring support & the shock body?
What is the spring rate on your N+?
i believe the cuscos would be a preload adjustment of some sort
8k linear front, 6k progressive rear
Old Jun 25, 2010 | 09:24 AM
JCrimson's Avatar
Thumbs up
Nino at Wirednj is the MAN! great guy, knows his stuff. very friendly and i believe he does go way out of his way to make you happy. A++++ recommendation.
Good choice sir
Old Jun 25, 2010 | 09:52 AM
FitDEEZ's Avatar
u are right about nino, helped me big time with my buddy clubs
Old Jun 25, 2010 | 10:28 AM
kummaz's Avatar
Thanks, I'll have to grab a set of adjustable ones then.
Old Aug 8, 2011 | 10:05 AM
  #32
taikahn's Avatar
SO sick, I have a set of these for the GE with like 50 miles on them that I'm trying to sell. Great coilovers.
Old Aug 9, 2011 | 12:20 AM
  #33
Undercover's Avatar
I just put mine in today and I'm trying to figure out how to lower the front. Any Buddy Club owners know how to? I've been searching and can't find anything.
Old Aug 9, 2011 | 09:46 AM
  #34
taikahn's Avatar
The entire shock threads into the lower portion of the front coil over.
Old Aug 9, 2011 | 04:31 PM
  #35
Undercover's Avatar
Can I lower it without taking off the setup? Cuz I did it for the back and it was extremely easy. Sorry first time doing coils and the japanese instructions didn't really help lol
Old Aug 9, 2011 | 04:32 PM
  #36
taikahn's Avatar
^yes, you can lower the fronts, you should be able to spin the strut into the bottom.
Old Nov 6, 2011 | 04:53 PM
  #37
Texas Coyote's Avatar
I needed pictures and found them here.
Old Dec 18, 2011 | 07:14 AM
  #38
ydna's Avatar
my front right coilover is making a popping noise every time i turn my wheel to the left. anyone know what it could be?
Old Dec 18, 2011 | 09:31 AM
  #39
Is it popping when you are when both rolling and sitting still... If it is only when you are rolling you may need to pull the boot from the CV joint and reassemble it correctly... The balls can fall out of place if the axle shaft becomes overextended ... When I helped Amanda install her Swift Springs I had that happen but I was able to manipulate things into place without removing the boot..... If you tried to remove the anti sway bar link without using an allen wrench to hold the bolt and keep it from turning you have messed up the link and it will need to be replaced by a new one... It will pop like crazy even when going in a straight line over the slightest bump on stock springs but with the stiffer springs and dampers set for a firm ride it may take a larger bump or a sharp turn to cause a noise from in.... You also could have not gotten the nut on top of the shaft tightened enough... I haven't installed my front coil overs yet so I am not aware of anything else that could be causing you a problem... Please post what you had to do to fix the problem when you figure out what it is... Murphy's law is sure to come into play when installing new parts with instructions printed in Japanese.
Old Dec 21, 2011 | 12:19 AM
  #40
JaySmith's Avatar
ClockWise or Counter ClockWise to stiffen? Sadly this wasn't explained in the intructions.
