Suspension Pic Thread
Old Jun 23, 2011 | 10:18 PM
  #61
apexanimal's Avatar
looks good!
collected another for our collection!
needed:
progress - ge
tanabe gf210 - ge
tanabe df210 - ge
t1r s coil - gd and ge
skunk 2 springs - ge
tein s-tech - ge
eibach pro kit - gd and ge
H&R sport - gd
eibach sport line - ge
also whatever c/o's are out there... we have several skunk2 c/o's on gd's, but nothing much else...
Old Jun 25, 2011 | 07:05 PM
  #62
n00b_stat's Avatar
Suspension: Megan Racing Full Adjustable Coilovers
Wheels: 16in Spun
Sway bars: OEM
Braces: OEM
Alignment specs: OEM
Is this your dd: Yeah.
Impressions: It's great. Although I was looking to tuck tire. Go low or stay home. lol.
Wheel/Tire: 15x7 +10 Drag Wheels DR-20 Khumo Ecsta 205/50/15 (Not my rims anymore, will take an updated picture though.)
Old Jun 25, 2011 | 07:29 PM
  #63
apexanimal's Avatar
^ looks great!
good to see a reasonable tire on those wheels
Old Sep 22, 2011 | 08:00 PM
  #64
apexanimal's Avatar
bump for moar!
Old Sep 24, 2011 | 02:43 AM
  #65
vinnymac's Avatar
09-19-11fitpix003.jpg?t=1316320168
ksportinstall08-06-11001.jpg?t=1312663443 ksportinstall08-06-11005-1-1.jpg?t=1316885954
KSport Pro's fully adjustable coilovers
Aspec front upper strut bar, Aspec rear mid and upper cargo bay strut bar
Tanabe front and rear under body sway bars
GSport 17"x7" Offset +35 f/r 205/40
Alignment Specs:OEM
Weight approx. 16lbs per rim.
DD-Yes, 50 mi. round trip daily.
If you are looking for function and comfort in your coilovers then I would recommend that you consider this set-up. You can also order the custom springs and rates that you want from the manufacturer +rep.. Best of all no rubbing....
Old Sep 27, 2011 | 09:58 PM
  #66
Bump. Also, people should post tyre sizing.
Old May 4, 2013 | 04:46 PM
  #67
Brandonlame331's Avatar
Originally Posted by ChristineK
Hey all.
I lowered my Fit some time ago. Here is what it looks like.
Another view
I am running 2 inch drop Eibach springs and American Racing 18" wheels. I am looking for drop shocks. I have Toxic Shocks on my S-10 and love them. I cant find anything but coilovers. Anyone?
I'm on Motegi DP6s 18" and I was considering the Sportlines. I rub at stock height, how did you solve it? Or did you?
Old Jul 12, 2013 | 12:29 AM
  #68
2poler's Avatar
Springs:
DropZone (Ebay cheapies)
Struts (OEM/Aftermarket):
Stock
Coilovers (any special spring rates installed? revalved?): N/A
Wheels (brand, type, diameter, width, offset, weight):
17x7 Konig Imagine 205/40 17 +45 offset
Sway Bars (OEM/Aftermarket):
rear strut bar installed, I have the front strut bar but need to get some stainless bolts to install.
Braces: N/A
Alignment specs (OEM or custom) (camber bolts/plates?):
Camber bolts (top and bottom) maxed out, no alignment I got it pretty close
Is this your DD? Autox? Road racing? Drag racing?
DD! 50 miles a day on the mean Chicago streets.
Impressions? Likes/Dislikes?
I like them so far. The ride is stiff and a bit bouncy at times but overall not bad at all for $50 shipped. I got these as a cheap spring for the summer and plan on getting some coilovers over the winter. When I found these on Ebay I could find very little on them and not many pictures so I thought I would post it here in case anyone else was curious about them
2008 Honda Fit GD3 by anasia13, on Flickr
(flickr does not do well on this forum at all)
Old Jul 14, 2013 | 09:31 PM
  #69
kostar's Avatar
I'm about to drop mine, love this thread!
Old Apr 19, 2014 | 07:41 PM
  #70
apexanimal's Avatar
Springs: swift
Struts (OEM/Aftermarket): tokico hts front, koni sport rear
Wheels (brand, type, diameter, width, offset, weight): rota, 16x7, 45et
Sway Bars (OEM/Aftermarket): stock front, progress rear
Braces: none
Alignment specs (OEM or custom) (camber bolts/plates?): -1.2 front camber, +1/16 front toe, -2.3 rear camber
Is this your DD? Autox? Road racing? Drag racing? Dd
Impressions? Likes/Dislikes?i like it a lot... The front camber really makes a difference, and all I would like now are some poly control arm bushings...
dotkayk@yahoo.com
Aug 17, 2012 11:52 PM
mugenfit79
Jan 29, 2012 02:34 PM
DynamicFit
82
Feb 25, 2010 06:07 PM
whtsjdm
May 20, 2008 12:20 AM
Squad808 Fit
Apr 12, 2008 02:16 PM
