spacer question.
Old Sep 30, 2011 | 06:06 PM
schuey1010's Avatar
spacer question.
I thought I had seen a thread about spacers and what works, but cant seem to find it. My question is I have stock Sport wheels, and swift sport springs. I am pretty sure people had said a 20mm spacer would be great with no problems.
Just want to confirm. I actually had a store online tell me that I could use a 38mm... seems a bit much, wow.
thanks in advance
Old Sep 30, 2011 | 08:07 PM
Goobers's Avatar
The thing about spacers is... they act like wheels with lower offsets. So, just look for threads that talk about various offsets (and even comparable tire widths).
For reference, I'm on Swifts, using 205/50/16 tires on 16x7" +43 wheels. Basically, it sticks out about the same as using 20mm spacers (10 from the wheel, 10 from the tire).
The front rubs a corner on the inner liner if you hit a bump during hard turns.
edit: oops, i was wrong about the offset of my wheels. corrected the above part.
Old Sep 30, 2011 | 08:25 PM
FITMugen's Avatar
15mm front and 25mm rear are the best fit.
jstorm
40
Apr 22, 2024 12:29 AM
A-Diggy
Mar 27, 2013 09:36 AM
liverpoolfcfan
Mar 29, 2012 08:01 PM
SenBlue09
Feb 13, 2012 12:55 AM
vbpsport
Nov 8, 2011 11:32 AM
