Buddy Club N+ Coilover Review
#44
mike, you are confusing. A car shouldn't need stiffer springs to clear a certain tire size... Either it can clear when the suspension is compressed or it can't. Having stiffer springs is just like hiding the fact that the combination doesn't work. I understand that Chris wants to use stiffer springs in the rear to hide that and I don't have a problem. But I would still consider that the wheel/tire combo don't truly fit, they just aren't causing problems b/c a stiff spring is hiding the problem. A big bump or a ton of weight in the rear will surely bring the problem to attention.
As far as your tie rod fitment, I am using stock ones and never had any issues on fitment and do not know of any other GD I know with buddyclub N+s that have had a tie rod issue
#45
#46
20 miles of non aggressive driving from the shop to home. chunked up tires, fucked up inner JDM bumper.
Look at the height and where the rub marks are... this shit travels more than a fucking pre runner truck.
#47
Maybe the adjustments aren't working. Maybe your set has problems. Maybe the coilovers really do suck. Jason already offered to meet up and try to figure out what's up. That seems like the best way to get to the bottom of this since your guys' opinions are completely different.
#49
Dude I had the same wheel and tire with 1 finger gap and I tracked it all day and taken it off road and never had any rubbing issues with the rear... Actually my rims were 1" wider than yours I believe. Like I said stiff springs will only hide the problem. If it can't clear then it can't clear... Mike I was talking about the fender edge and bumper to the tire, not the tire to the inner wells of the fender.
My friend that works at buddyclub tried calling you twice to speak to you about the issues and you chose to ignore his call two times and not call him back so I don't know what to say. You're not taking odd steps for the situation and your impressions have not come from a well thought out mindset, sorry but I tried to help
#50
I appreciate that you took a concern and tried to assist... but also realize that I know what I am doing, and took the appropriate steps to handle this situation, which got me nowhere.
#51
Stiffening up the coilovers will not make the issue better, It's obvious that the spring is what is causing your problem. That's why I suggested for you to try any other springs like maybe from your old coilover kit if you have it on hand to see if it fixes it. I had the same thoughts when I first put on the coils which is why I found a spring with the same rate but linear not progressive. After I did that, I never needed any additional changes to the coilover. I would say that thie springs they come with under normal driving feels just as soft as stock, that's why there is so much travel
#52
#53
If you already knew that, why didn't you wait to give your impressions after trying it instead of saying that it was terrible and you would no longer use the product and shun it? A post made after you try stiffer springs saying that the one is comes with doesn't work for you with the outcome of trying out stiffer springs would make a lot more sense.
He did call you back 2 times, not in the same day, and he said both times he didn't hear back from you. I can let him know to expect your call today, but it looks like you have no plans of using them anymore since you said it's off the car now?
#54
He is a fucking liar then. He called me once when I originally contacted him, and I spoke with him. The only other time he called was the 1 time on Friday. And the reason I posted it, was because after I modify it to work correctly, it is just that.... a modified kit. Not the Standard BC kit that comes from them. And I am still having issues with the front. Makes me think they gave me a GE kit. If I had stock wheels/tires it would have still rubbed. So again, my wheel/tire setup was not solely to blame for the rubbing.
Edit: the rear suspension is off the car. I have my previous coilovers back on the rear.
#55
I highly doubt stock wheels can rub... I've seen some fits on stock wheels dumped to hell with no problems, haha
Anyways I'll txt him to let him know that you may call him today, not sure how to tell if it's a GD/GE kit but I'm sure he'll know what to do then.
Maybe he counted that one time he spoke with you as one phone call and the time he called and you didnt pick up as another? Lol no need to say he's a fucking liar. He doesn't speak english super well so there might be a language barrier there
#58
If he is saying i am not calling him back... then yes. Also I tried calling him today and I was told he is not there.
